Old 05-25-2019, 05:18 AM
Bargas300 Bargas300 is offline
Originally Posted by Davehuge View Post
Hmmmm, back firing after 3 hours... intriguing... another woodruff key sheared?
Have you got a flywheel puller?
Keep us posted!
It could also just be a fouled spark plug, I would try a new plug first.
Done all that . Was fine then went to start but no go. Other than a possible sheared key the filter installed by the factory or dealer wasn?t installed correctly...bottom right corner sealing face of the filter folded back. So check your air filter when a new bike gets delivered ( no matter what make )
Old 05-26-2019, 04:15 AM
Pull the flywheel Steve!!
Old 05-29-2019, 04:19 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Any update?
Old 06-01-2019, 02:14 AM
rodent's Avatar
rodent rodent is offline
Yeah, any update? I'm picking up my new EC 300 from the dealer next weekend........enquiring minds gots to know
Old 06-01-2019, 02:34 AM
Davehuge's Avatar
Just for peace of mind, I would ask your dealer to check the torque of the flywheel nut before you collect it, it'll only take them 5 minutes, I'm sure they wouldn't mind.
Or even better, check it yourself when you get it home.
Have fun on your new bike, I'm sure you'll love it!
Old 06-01-2019, 02:42 AM
Davehuge's Avatar
I don't want to give GasGas any bad press (I'm a big fan) or make a mountain out of a mole hill.
I might be jumping to conclusions unnecessarily, it's just that I've recently read of two new/low hours bikes that have sheared the woodruff key.
A quick check of the flywheel nut might prevent you from getting stranded.
Old 06-01-2019, 03:10 AM
rodent's Avatar
Thanks for the reply Dave I'm going to get them to check it before pickup, I'd rather it didn't become my problem
Old 06-08-2019, 03:30 PM
Davehuge's Avatar
Hmmm mine has stopped and has a back fire on about 3 or so hours on it (128km) . About to compression test and check the flywheel key ....mine is a 19 also .
Hey Bargas300... what happened? Give us an update!
Hope you've got it sorted.
All the best, Dave.
Old 06-08-2019, 05:36 PM
I was following on FB. Pretty sure he posted a picture showing some damage to the top edge of the piston (viewed through the exhaust port). Not sure where it went from there though.
I was discussing the flywheel sheering with my dealer last week when I was in the shop. The issue is that the factory has been using a dry thread sealant/pre applied loctite. The lack of lubrication (and possibly a lower than expected torque spec), means the torque wrench is hitting spec and clicking before the bolt bottoms out.
I think I might pull mine off and have a look.
I also saw a post on FB where a couple others have had the smaller bolts holding the ring gear onto the flywheel back out.
Old 06-09-2019, 04:27 AM
Davehuge's Avatar
Thanks Jakobi, that's interesting and explains everything.
I don't use FB as I firmly believe it's the work of the devil.
So it sounds like the factory are aware of the issue and will have rectified it. I hope dealers are checking any bikes that might be affected as they pass through.
All the best, Dave.
2019 ec300 fuel mrquick Enduro Engine - 2 stroke 76 09-29-2021 01:58 AM
2019 EC300 Review Jacob 'Berg General Discussions & Announcements 2 06-01-2019 12:22 PM
2019 EC300 Engine Vibration RudolfHucker Enduro Engine - 2 stroke 30 02-27-2019 09:49 PM
2019 ec300 Saddleback51 Enduro Intake/Carburetion - 2 stroke 0 11-08-2018 12:26 PM
main bearing failure right side 2006 ec300, rebuild tips needed. hillbilly Enduro Engine - 2 stroke 11 03-16-2012 04:42 PM
