Old 01-05-2017, 07:13 PM
LTPC LTPC is offline
Default Ec200 top end
Hi gents,
Am about to order a new piston for my 2013 Ec200 and just want to double check what I'm about to order is correct....
The bike has aprox 65 hours, the cylinder in marked A and the current piston is an s3 vertex type A with 62.44 printed on the top.
After some research I want to go with a Wossner piston but according to their website the A piston for the ec200 measures 62.5mm which is a bit larger than the current OEM one. Will this be safe to use given its an A piston?
The other manufacturers all look to only have 62.5mm pistons for the ec200 as well.
Old 01-05-2017, 08:22 PM
hamilton's Avatar
hamilton hamilton is offline
The std bore is 62.50mm. 62.44 piston would be "A" size, 62.45 "B" etc.
The Wossner A piston will be fine. Always a good practice to measure the bore if you have the tooling.
15 GASGAS EC 250
19 Sherco SE 125R
Old 01-05-2017, 11:09 PM
I've done some more reading and it seems like Wossner quotes the bore size rather than the piston size. They say the piston has a clearance of 0.05mm which would mean the piston itself should measure 62.45mm.
Can anyone confirm this?
Old 01-06-2017, 09:23 AM
john r b's Avatar
john r b john r b is offline
Yes, you are correct. Wossner # 8139DA 62.45 mm clearance of 0.05mm
Pin WP040 Clip CW18 Rings 2xRSB6250
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 01-07-2017, 06:44 AM
barossi73's Avatar
I did exactly that on my 13 200 at 70hrs no problem.wossnerA for vertexA.the small end bearing supplied was wrong width so check it against the old.the correct one is a yz250 part crossover.
The gasket for the coolant 't' on the head
is not included in the set,and the washer on the small coolant drain bolt may disintegrate when you loosen it.
Dont pull the pv linkage rod up too much at any stage,*on reassembly of pv rod to pv actuator (rh top) its easy to accidentally do this as you tighten nut clockwise.
Enjoy!
2013 ec200r
Old 01-07-2017, 07:48 PM
Enjoy!
Thanks for the tips. They are great bikes aren't they!
Where did you buy the Wossner? Trying to find a reputable seller that stocks them and ships to NZ.
Old 01-07-2017, 11:45 PM
barossi73's Avatar
I got mine thru a mate with yamaha dealership,id imagine most bike shops will have wossner parts list.ktm/yamaha dealers are probably the best bet/or online.wossner 8139DA ec200 03-09
Ignore the 09,theyre all the same
2013 ec200r
Old 02-28-2020, 02:26 AM
hannesd hannesd is offline
hi, a very late response to an old thread, but i'm about to buy a 2015 ec 200 and i'm looking into parts.
is it correct the pistons of all years fit?
i have seen listins of pistons fitting from 03-09 and then from 14-15 ?
what about this?
cheers, hannes.
Old 02-28-2020, 03:12 AM
Anders Anders is offline
what about this?
cheers, hannes.
The 2015 EC200 is a good bike in my opinion. I have one, and had it since 2015. I really like the way it handles.
I cannot se a reason why the pistons should be different between the years.
Generally, parts availability has been good so far, the future is hard to predict. Marzocchi fork parts can be hard to come by, but normal things like seals and bushes are no problem.
Wtb: Ec200 offroadingisbest "Wanted to Buy" & "Want To Trade" 7 01-26-2015 03:51 PM
First rip on the EC200 liv2day Ride Reports 22 11-20-2013 11:34 AM
How About A EC200 ???? victorykid GasGas Member Polls 41 06-17-2013 11:11 PM
99 EC200 for my dad sled_fiend General Discussions & Announcements 5 07-09-2009 09:36 PM
