Old 05-20-2011, 12:08 PM
speeddemon speeddemon is offline
Default rear wheel bearing completely shot
Went from work to my home and suddenly the rear felt very unstable , luckely i was 0,5 km from home. Then home i noticed my rear fender was scrubbing my rear tire, so removed that. Then went for a test, no improvement. I then checked my rear wheel and noticed the wheel bearing on the left side was gone with a thin iron ring still hanging on it, the rear axle loose in the wheel and the chain very loose. This is the second time a rear wheel bearing breaks down, but the first time it breaks down comletely. It's a weak point of the bike because the bearing is unprotected on the outside of the rear wheel,
Does anyone have a suggestion how to protect that bearing from impact?
I know that this will keep on happening once in a while and i don't want to risk being stranded or worse.
Gas Gas Halley 450
KTM 690 Enduro R 2010
Triumph Speed Triple 955i
Old 05-20-2011, 02:21 PM
stainlesscycle's Avatar
my rear wheel bearings get destroyed fast. i replace them 3-4 times a year. i only buy quality bearings.... i have ordered checkpoint machine's hard coated wheel spacers, to see if this fixes the problem.
07 ec300
www.stainlesscycle.com
Old 05-20-2011, 02:51 PM
mrkartoom's Avatar
mrkartoom mrkartoom is offline
What am I missing? Is there not a seal there?
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250
Old 05-20-2011, 04:10 PM
seals are there - but i think the soft spacers let the wheel move side to side and destroy the bearings? all i know is the bearings wear out extremely fast on my rear wheel. i put a set in earlier this year, have run 6 or 7 2 hour races, and they are shot already. back wheel wiggles...before i put more bearings in, i'd love to solve the cause.
07 ec300
Old 05-20-2011, 05:08 PM
mrkartoom's Avatar
I was a bit confused by this statement: "bearing is unprotected on the outside of the rear wheel"
Mine's new and I haven't had a wheel off yet, but that's seems way premature to wear one out.
Old 05-21-2011, 04:21 AM
What I mean is that the bearing lies on the outside of the wheel and there's space between wheel and frame so dirt can get in the seals and after a while the bearing will get shot. I would recommend changing the bearings every 10-15 hours if you only ride offroad or every 50 hrs if you ride it dual sport like me . Will now change the bearings every time i fit a new rear tire. My bike eats rear tires so that's not a bad idea i think.
Gas Gas Halley 450
Old 05-22-2011, 05:04 AM
GasGasDreamer's Avatar
GasGasDreamer GasGasDreamer is offline
1-i always pop the plastic seals off a new bearing and pack it with some hi quality bearing grease.....the factory doesnt grease them enough
2-on my old honda cr500, there were two bearings stacked on top of each other on the chain/drive side. i think this is a great idea but i dont how feasible it would be to make this work on a gasgas.
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
2014 Beta Evo Factory 300
Old 05-22-2011, 02:48 PM
bchatt's Avatar
bchatt bchatt is offline
Bronze Level Site Supporter
Um, my 07 has this - 2 bearings. Inexplicably they are different sizes, which is why the aluminum spacer washer is in there. I got 180 hrs out my last rear bearings and even then only one had crapped out due to water ingress. I have replaced all and packed with marine waterproof grease between them and the seals.
Barry
07 EC250
Old 06-29-2011, 05:55 AM
McGuiver McGuiver is offline
Where do you get the hardened spacers? Mine are shot, and would like to replace with something better.
Old 06-29-2011, 06:09 AM
checkpoint offroad has spacers. unfortunately they do not work on the early bikes. 03 and up only.
http://checkpointoff-road.com/store.html
anyone know if there are any available for the earlier wheels???
07 ec300
rear wheel bearing shim spacer dimensions? mattlloyd50 Enduro Chassis & Body 17 07-24-2010 10:13 AM
wet clay + shot rear tyre = fail boundy Pictures & Videos 21 03-31-2010 03:32 PM
Rear Wheel Bearing 2001 XC250 thomasbyrd Enduro Chassis & Body 0 10-04-2009 02:04 PM
MC65 rear wheel bearing change bergerhag Enduro Chassis & Body 0 03-12-2008 03:16 PM
Rear wheel bearing ? ktmguy23 Enduro Chassis & Body 1 03-22-2007 06:45 AM
