Old 10-06-2018, 02:24 PM
Rampart Rampart is offline
Default is it normal? right power valve cover EC300
https://youtu.be/qBF5b0GxLQQ
looks like it have some free play ?!
Old 10-06-2018, 05:00 PM
Some free play is normal.
It can be adjusted out. Do a search on power valve adjustments.
By the way.
Avoid moving the power valve lever like you're doing.
Sometimes the governor balls can become dislodged.
Old 10-08-2018, 02:16 PM
can't find anything about its adjustment
Can someone help?
Old 10-08-2018, 04:52 PM
eralha eralha is offline
https://www.youtube.com/watch?v=hmz9cij6MVY
this guy explained it realy good, you just need to adjust the knob that touches the governor, to remove free play.
Old 10-08-2018, 05:02 PM
Here also.
http://gasgasrider.org/html/pv_disassembly.html
Old 10-09-2018, 11:37 PM
I'm understood, thank you!
Old 10-13-2018, 06:48 PM
Hello friends
So I adjusted my PV.
And here is the result I got.
https://youtu.be/nY0fq1kaNJE
Should this slider reach the top bolt?
In the video, it does not reach the end, the valve is closed by about 2 mm in this position. But it should be noted, I think I did not reach the max rpm, because I could not warm up the bike well, and it was very rich.
Old 10-15-2018, 06:06 AM
Has a ride yesterday, it looks like it is necessary to change jets, I did not understand this because of this edjust of PV, but it seemed that there was not enough power at max revs. At the same time, it seems good pulls at low.
Old 10-15-2018, 09:29 AM
what year is your bike? does it have the preload tensioner?
this mechanism: https://www.youtube.com/watch?v=lu3T-ctnzKY
if it have maybe it has some preload and not letting the PV full open.
Mine has that mechanism, and i have some tension on my PV so it does not fully open, and as a result i have more low end power, losing some top end power wich i dont need any way.
Old 10-15-2018, 01:28 PM
2011 and there is no such mechanism.
It seems that I did such a preload when i adjust my PV ...
EC300 suddenly low on power but then returns back to normal Mika Enduro Engine - 2 stroke 3 11-13-2017 01:01 PM
LTR Power valve cover skid jackson Enduro Product Reviews 22 09-04-2017 02:42 PM
EC300 power valve's left cover assembly question Rampart Enduro Engine - 2 stroke 3 03-27-2017 12:12 AM
LTR power valve cover $40.00 GAKLX Parts 6 10-04-2013 09:42 AM
LTR power valve cover Bailey28 Enduro Engine - 2 stroke 11 02-16-2011 04:23 AM
