2011 EC250 Died
Hello
Bought this from a member on here 2011 EC250 Just been fully rebuild, barrel replated, wiseco piston, carb rebuild It started fine when I bought it I ran it up my garden In the morning started first kick and I ran it down the street at about 20mph nothing mental it then spluttered, internally backfired and died It?s getting a spark I?ve removed the carb, jets and cleaned it all Checked the floats Checked cables to cdi unit Changed the plug Changed the fuel Tried bumping it (just bogs and doesn?t give anything) Removed the manifold and there was a few spoonfuls of fuel(black) Left the plug out and kicked it over a dozen times It you kick it on full throttle it will backfire occasionally Tried a spoonful of fuel down the cylinder with the fuel off and nothing Checked the piston and liner as much as you can and it looks Ok Seems to have compression I?m at my wits end with it, absolutely gutted I?ve just got it and this has happened. Going to drop it to a bike shop Tuesday but ideally would Like to sort it myself |
2003 450 FSE Died Suddenly and No Longer Runs Right! | cruzer555 | Enduro Engine 4 stroke (including EFI & Exhaust) | 9 | 09-02-2015 12:52 PM |
'05 FSE 450 died,,,,,,,, | houndog | Enduro Engine 4 stroke (including EFI & Exhaust) | 5 | 01-10-2015 05:59 PM |
EC 250 1997 CDI died ! | EC250 | Enduro Electrical & Wiring | 2 | 10-19-2014 06:30 PM |
EC200 died on straight gas with no premix oil. | Zman | Enduro Engine - 2 stroke | 25 | 07-09-2013 07:49 PM |
2004 ec300 died newbie helpp!!!!! | jt633 | Enduro Electrical & Wiring | 1 | 03-05-2013 04:00 AM |
