Old 07-17-2016, 11:12 PM
Flyn Flyn is offline
Default Injector
I have a 05 wild hp450. I need an injector. Does anyone know of a crossover or have one for sale.
Old 07-18-2016, 02:22 AM
Tafka Tafka is offline
Last two posts:
http://www.gasgasrider.org/forum/sho...t=11074&page=2
Injector code IPW043. I ordered one from aliexpress...have'nt fitted yet but in few days can let you know if it works
Old 07-21-2016, 07:47 AM
Okay, installed new (cheap) injector from Aliexpress and works great. First trail ride done and no problems (Y)
Old 10-14-2016, 12:50 PM
johnalex's Avatar
johnalex johnalex is offline
Thanks. Ordered one off eBay from China. Should be here within a week.
Later...
Got the Chinese injector. Did not like the way the motor sounded.
Decided to send off the original for ultrasonic cleaning at Injector RX in Houston.
John Alexander
2008 FSR 450
Santa Barbara, California USA
Old 10-15-2016, 02:26 PM
Let us know how it worked....i must admit i threw that chinese injector away....couple of rides and the fuel economy was terrible and engine didn't work good. Cleaned and tested original injector and seems okay now.
Old 10-17-2016, 06:46 PM
johnalex's Avatar
The injector arrived in today's mail.
Installed it but will try it out tomorrow.
It's the IWP043 which is compatible with IWP162 found on the bike originally.
IWP043 has a brown ring.
The IWP162 has a white ring.
They flow 330 cc/min at 3 bar.
10/18
So far.
Each time I try starting the engine it fires but then acts like it has run out of fuel.
Letting it rest now to recharge the battery on its tender.
10/19
Well, got it to start. Idled just fine. When throttle is applied it balks.
Let it rest a bit and it ran much better.
But, an hour later, gas all over the floor.
Turns out the O-rings are a bit smaller on the new injector.
Save your old O-rings to put on the new injector.
10/26
Reinstalled the original injector after a YouTube cleaning.
Starts and idles just fine.
Runs fantastic. Do a 30 mile loop from sea level to 5,000'.
Running better than ever.
Start back down and the original problems return.
Make home, pull injector again and...
Send off for professional ultrasonic cleaning.
11/2
Injector arrived in today's mail.
Injector RX in Houston cleaned ultrasonically and flow tested.
Installed and bike idles fine.
There is a bit of a lag when I blip the throttle.
I will do a test ride tomorrow to evaluate.
Ok, injector back from Injector RX in Houston.
http://www.injectorrx.com
Bike starts right up, idles and now for a test loop.
No more bogging. Everything nice and smooth.
Pulls from all rpm's.
Only need to fiddle with the idle a bit.
Very happy.
HTH
John Alexander
2008 FSR 450
INJECTOR cross referrence?? McGuiver Enduro Engine 4 stroke (including EFI & Exhaust) 14 07-04-2012 10:40 AM
fuel injector removal from throttle body 450s ggg Enduro Engine 4 stroke (including EFI & Exhaust) 1 06-20-2010 10:11 AM
450 injector crossover? bergerhag Enduro Engine 4 stroke (including EFI & Exhaust) 3 03-23-2008 06:44 PM
07 FSR 450 injector problem? GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 14 03-10-2008 05:51 AM
