#11
Post a question in the engine section, surely someone can recommend a good top end pipe.
#12
I take it I remove the cylinder, add more gaskets, tighten it back down and with the pipe removed look to see that I can't view the piston at bdc (the top of the piston should be just below the port)? Will this make extremely peaky? Or should the piston be 1mm above the bottom of the port as a compromise???? Last edited by krazy; 04-01-2011 at 01:12 PM. Reason: update |
#13
If you handle the gaskets very carfully after determining the correct combination you can use permatex copper spray gskt and coat all sides before restacking for final assembly. just make sure you give them at least an hour to dry before handling.
#14
Stock pipes can be modified for top end power. Not really practical but for somebody who really wants to do it.
#15
Was looking for a fairly cost effective solution.
#16
Could you just advance the timing of the stock cdi? I take it I need to retard the timing of the black cdi unit. Are the only differences between the boxes the timing advance? For anyone else wanting to read up on CDI - http://www.vespamaintenance.com/elec/cdiwork/ |
#17
With the stock box, you can only change the static timing. If you change the static timing by one degree, you change the entire timing map by 1 degree.
blitz |
#18
Wait for the "Blitz Box".
What do you think Craig? Has a good ring to it! |
#19
It does have a nice ring to it. You might have a future in marketing if your engineering gig doesn't work out!
I finished the Rev 0.0 circuit board design tonight (I have to check it tomorrow when I am fresh). Before I send it off, I need to wirewrap one and have it running in the bike to convince myself that it works. Then finalize connectors. That's my plan for this week. Well, that and making sure my USB to RS232 cable works like it should. I am not a circuit board guy at all, so this has been a bit of a learning curve. I tested a few PCB/Schematic design tools, and found one which is OK. (But still not great.) I'm better at having people do this for me, but we're not at work, so..... If the breadboard works well, i might redesign to go surface mount, and have someone populate the boards for me. Time will tell. I am done with the First Robotics deal and mentoring the 8'th grader, so perhaps this will become more expeditious. blitz |
Dual map CDI on 250 | GMP | Enduro Engine - 2 stroke | 32 | 01-19-2014 11:23 AM |
Dual Sport ???? | victorykid | General Discussions & Announcements | 3 | 11-17-2010 03:02 AM |
Dual Map switch.. | stevehipkiss | Enduro Electrical & Wiring | 3 | 01-28-2010 01:29 PM |
Dual Sporting a 2T | kendunn | General Discussions & Announcements | 0 | 12-18-2009 06:46 AM |
Dual Map on a 2001 EC250 | ducncover | Enduro Electrical & Wiring | 4 | 03-03-2008 03:42 AM |
