You can run zero pressure with no problems if you use slime in your tire. A lot of people think the slime would be a big mess but probably it won't be. I have yet to change tires since mounting the Tubliss but here is why I think the slime mess will be minimal - the slime is in the tire not the Tubliss system. What little slime is on the Tubliss after removing the tire should be easy to wipe off (the Tubliss is not removed for tire changes).
How long before they wear out? I'll just throw out random numbers but say you road 60 miles a weekend every weekend for a year. Think it would last that long?
2006 Gas Gas EC250 2011 Husaberg FE390 |
How do you all keep your wheels round with that low of pressure? Seems I have enough problems bending rims at 11 to 12 psi.
Roscoe
Huge thanks: GAS GAS OFFROAD US, Skagit Powersports, Cycle Gear, LTRacing, Scorpion Racing, users of GasGasrider.org, and CFMC! |
here's my theory on it. on a regular tube, the tire is only held on the bead by 10-12 psi. so when you take a hit at 10 psi, the tire unbeads (kinda) and 'gives' (temporarily) and the rim takes the hit. the tubliss holds the bead at 100psi. this pressure holds the bead much tighter than the tube at 10psi can. the rubber takes the hit.
the only time the tubliss gets wear is when you install it. you don't need to take it out when you change tires. it stays on. it actually makes tire swaps easier. no tube to mess with. is it worth $180 for 2 tubliss? i dunno. you could run a whole year without replacing a $20 tube. but you can't run low pressure with a tube, so it's totally worth it to me.... if you're doing any amount of serious dirt, it's a great investment. i see no reason to ever buy a tube again for a dirt bike..
Have you done such patching? I tried once but it didn't work so I purchased some spare inner tubes from Jeff (praise his patience and attitude). I did take the punctured tube later to a repair shop where they deal with truck tyres and I believe their patch manages to withstand the 100 psi pressure. Haven't tried it though.
i nicked the inner tube during install and had no problem patching it. i only ran for a few days that way, but it worked fine.
I'm going to TuBliss with slime as soon as I need a tire, tube, wheel, or any other reason that might have the rear wheel off my bike. I'm just too lazy to fix what's not broken. If I was competing next week then I would have already ordered them.
I had issues with the inner tube getting punctures, only the back though, and i know that a lot of guys got sidewall cuts in the sharp rocks, so advisable to go with a strong sidewall tyre like motoz, mitas or maxxis. If you are a racer then stick with a moose, it is the lowest risk, unfortunately probably gives you the worst handling
Force Radiator Guards Install Q | Brian | General Discussions & Announcements | 3 | 06-13-2010 01:14 PM |
Attention: AMSOIL 0W-40 users | tommie d | Enduro Other... | 7 | 02-15-2010 09:48 PM |
I banned some users by mistake... | webmaster | General Discussions & Announcements | 4 | 02-07-2010 09:52 PM |
Attn. No-Toil users | rider01 | Enduro Intake/Carburetion - 2 stroke | 1 | 08-21-2007 04:37 AM |
top end install help!!!! | rdbandkab | Enduro Engine - 2 stroke | 12 | 01-19-2007 04:20 PM |
