Old 09-21-2017, 04:44 PM
Davehuge's Avatar
Davehuge Davehuge is offline
Default Float valve seat removal...?
Hi all
I have a 2004 EC300 witn a PWK38 ASI carb.
1. Can anyone tell me how to remove the float valve seat without damaging it?
2. Can anyone tell me the dimensions of the O ring?
I need to remove it and replace the O ring as it's leaking and causing the float bowl to overflow.
Thanks, Dave.
Old 09-21-2017, 08:24 PM
You know my brain is not accessing the information on pwk. I know the 28s are just in the body.
Either way check for hairs and crud in the tank. Esp once on reserve. Mate's one emptied in my van. Took months to get rid of the smell even after we ripped carpet out.
A ball bearing dropped down the hole and tapped smartly with a punch can resurface the hole often.
Old 09-22-2017, 04:09 AM
Davehuge's Avatar
Hi F5
The float valve is closing and sealing correctly in the valve seat.
The problem is the fuel still flows around the outside of the valve seat, I'm guessing the O ring has failed, I'm guessing there's an O ring in there?!
Has anyone ever removed the valve seat?
Thanks, Dave.
Old 09-22-2017, 05:25 AM
Can you spray it with some lube and then use two small, sharp, flat blade screw drivers on opposing sides to work it up/out by using the carb body as the fulcrum?
Old 09-22-2017, 06:41 AM
There are some videos on YouTube showing how to remove the valve.
Old 09-22-2017, 07:22 AM
pscook's Avatar
pscook pscook is offline
I believe the seal is on the end of the needle, and the seat in the carb is brass. Check the end of the float needle for wear; also check the string tip at the other end of the needle - if it doesn't have any "spring," then it can't press the rubber seal into the seat.
Last, as above, use a ball bearing to lightly "reshape" the brass seat inside of the carb body, if everything else checks out. However, for cost and hassle, I would probably just buy a new float needle before I start trying to modify anything inside the carb. It's likely less than $10 for a new needle, and with that common of a carb they have to be everywhere. Maybe try Sudco?
Phil
(New bike pending...)
Replacing Float Seat ORing on 2012 GLantern Enduro Intake/Carburetion - 2 stroke 9 11-30-2013 12:12 AM
Power valve flapper removal Krasi Enduro Engine - 2 stroke 14 05-29-2011 07:15 AM
Power Valve Removal cdn280 Enduro Engine - 2 stroke 6 01-23-2010 05:34 PM
Ohlins Base valve removal PEB Enduro Suspension 5 09-01-2008 07:55 PM
KEIHIN float valve nhrider Enduro Intake/Carburetion - 2 stroke 1 06-17-2008 01:10 PM
