Old 06-23-2013, 12:44 PM
gasser's Avatar
gasser gasser is offline
Originally Posted by Zman View Post
So Far So Good. The cylinder looks pretty good with no significant issues. The connecting rod big end is JUNK! I have never seen one with 1/8 inch of play before. We will split the cases tomorrow!
I can't imagine the case hardened steel rod bearings being softer than the nikasil walls of the cylinder so even though the cylinder looks good it needs to be accurately measured to see if it's still within wear limits.
Old 06-23-2013, 05:39 PM
Zman's Avatar
Zman Zman is offline
I agree, I am going to have Eric Gorr check out the cylinder while I get the crank rebuilt.
Old 06-24-2013, 11:17 PM
Zman's Avatar
I took off early from work today and ran the EC200 parts up to Finish Line Engines in Beaver Dam, WI. Ryan Callies (owner) rebuilt the crank, diamond honed the cylinder and ported/polished the cases. Ryan is great to work with, fast and has very fair prices. www.finishlineengines.com I am looking forward to heading back up later this summer to run my big bore XC327 on his Dynojet dynamometer to see how close my jetting is and how much power she makes.
Now I need to order some parts so I can put it back together.
Old 07-07-2013, 10:20 AM
Zman's Avatar
36hrs plus $980 and we have a fresh and clean 2004 EC200 for my youngest son to ride. $1380 bike and parts total invested, minus $400 for the extra parts that came with it including the parts I was getting ready to buy for my bike, (Big Clarke tank, new front rotor and pads).
This bike really runs really well for a 200. With a single ~0.014" base gasket the squish was around 1.7mm. I am sure the polishing of the cases and cylinder helped too.
Old 07-09-2013, 11:10 AM
Rick's Avatar
Rick Rick is offline
What was replaced....please provide some insite on the "fresh motor"
I would like to get my 99 rebuilt as well.
Did you replace all tranny bearings as well?
Thanks
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 07-09-2013, 07:49 PM
Zman's Avatar
I had the connecting rod replaced/crank rebuilt, new crank bearings, cylinder diamond honed (Finishline Engines $200), four new transmission bearings (Grainger $75), crank seals, gaskets and wiseco piston kit (GasGas $350). The prices maybe off a couple bucks one way or another. My output shaft seal, shift shaft sealand kickstart seal looked ok so I left them because they can be replaced later if/when they go bad.
After the fact I found that All Balls has a kit with crank bearings and seals for $80.
I would love to find a second source for GG alcohol friendly crank seals.
2013 straight out of the box - UK Biff Enduro Intake/Carburetion - 2 stroke 42 06-12-2013 01:55 AM
2004 ec300 died newbie helpp!!!!! jt633 Enduro Electrical & Wiring 1 03-05-2013 04:00 AM
2008 motor in 2004 Frame...is it a straight swap ?? DaveH Enduro Engine - 2 stroke 10 01-14-2012 04:49 AM
Premix 1:60 sasa Enduro Intake/Carburetion - 2 stroke 6 11-15-2011 07:41 AM
premix W8TSON Enduro Engine - 2 stroke 31 08-11-2009 09:52 AM
