#11
hi guys.Thanks for this post it has been very useful, but I still have and issue whit this. My power valve in my ec300 2019 is working the opposite way. Let me clarify. If I turn it in (1 to 1.5turns from close to open) it revs quicker that if say I open it to more than 2 turns. 2 turns or more (from close to open) makes the bike very slow revving as like it stays forever with the PV closed.
Note. I am higher than 10.000 feet with more than 20 degrees celsious and poor gas... so I dont know if my conditions are affecting or my PV is malfunctioning. |
#12
That's very strange as it is exactly opposite than it should be. I have done several test sessions with three Gassers (2 of them 2018 GP one of them a 2019 EC, all 300's).
I found it to be the same on all bikes. Turning the adjuster fully in (clockwise) makes them slow revving and weak. The further I turn the adjuster out (counter clockwise) the more toque the motor gets until it looses torque at about 2 turns but after that starts to rev faster until it explodes at three turns out (counter clockwise). Are you sure that you are turning in the right direction? |
#13
Same here...I have my 19 EC300 at 1.5 turns out (counter-clockwise) for very smooth delivery. I can go to 2 turns out for a little stronger delivery.
#14
Im switching to a new cylinder on my 2015 bike with the same type of rod connection as in the video. Noticed that my "male part"/pin is quite loose and can point up or down. Bad description maby... Im guessing it should be fixed/welded to the pointy plate its sits in. Is that right? /Mathias |
2018 ec 300 power valve issue | Sterlo300 | Enduro Engine - 2 stroke | 8 | 10-27-2018 08:46 AM |
2018 XC 300 Power Valve adjustment | Islander | Enduro Engine - 2 stroke | 3 | 07-11-2018 09:44 AM |
Power valve adjustment on 15 engine | Adam500 | Enduro Engine - 2 stroke | 3 | 03-24-2017 07:14 PM |
GasGas (all years) exhaust valve adjustment | Leo | Enduro Engine - 2 stroke | 5 | 01-31-2016 12:24 PM |
Power Valve Adjustment | Skele | Enduro Engine - 2 stroke | 2 | 08-17-2009 08:31 AM |
