Old 05-07-2019, 02:55 PM
Leelee Leelee is offline
Default 250/300 gearing
Hi guys i have a 2019 ec 250 but i belive it was a 300 and the importer changed the barrel and piston to make it a 250 as there were non left when i wanted one.
Its a brill bike but it feels like theres a big hole in the gearing just before the power valve opens, not like my 2018 250?? I have not played with the pv yet i will this weekend, but my question is are the gearbox ratios the same??
Old 05-07-2019, 04:22 PM
What gearing did you run on the old one? Did they change the CDI as well?
Old 05-07-2019, 09:44 PM
Throw the stock 48 tooth sprocket in the bin and get a 50. Or if you don’t want to buy a new chain and rear sprocket, just throw a 12 tooth on the front for now. Also set the PV at 1.5 turns out as a baseline. Pull the stock needle out of the carb and bury it somewhere so it can never be found and go with a N3CH or NEDW/NEDJ needle.
Old 05-08-2019, 03:59 PM
Hi memphis its got the suzuki nesle in it and 13/50 sprockets same as my old 250, i assume they did the ecu as it was the main importer who did the swap.
Just dont feel the same but i have not touched the PV yet, guess i will do that and see how it feels 👍
2018 XC 250 Gearing J. JuJu Enduro Chassis & Body 2 08-27-2018 10:14 PM
FSE gearing spencergt66 Enduro Chassis & Body 1 07-11-2016 01:40 AM
200 gearing dirtyDsun General Discussions & Announcements 6 06-05-2015 11:32 PM
250 gearing skid jackson Enduro Chassis & Body 12 10-17-2011 08:23 AM
Gearing down an XC 300 Krieg General Discussions & Announcements 15 01-29-2011 10:03 PM
