Old 05-24-2017, 02:29 PM
Sjoblom! Sjoblom! is offline
Default No spark ec300 2006
Hi! I'm in a bit of hurry since I've signed up for a race this weekend.
During practice monday, it just died on me. No missfires,no hesitation before just completly died.
So, the spark is the issue. I started looking in to it yesterday. Wendt through all wireconnections, changed the plug, took the flywheel of and cleaned it.
No results, so i tried my friends ignition coil from a TM racing 250, and tadaa! Spark!
So i got a hold of a usel coil today. Mounted it, But Nope. No spark. Tried my friends TM coil again. No spark.
That tells me i probably have some wire that have gone bad somewhere. Right? Or could the cdi / stator flip out and internally have bad connection or something?
Electricals is'nt my best mechanic skill..
Regards Philip, sweden!
Old 05-24-2017, 03:18 PM
Getoviq95 Getoviq95 is offline
Turn off a stop button ,and see the impulse coil .
Old 05-24-2017, 03:48 PM
The stop button is disconected. I took the wiring apart up at the handlebars. That should do it?
What do you mean with see the impulsecoil? My english is not What it used to be..
Old 05-24-2017, 03:56 PM
Anders Anders is offline
Check the ground connection where the coil is fixed to the frame. On my 06 200 it was quite rusty there.
Norway :-)
Sent fra min E5603 via Tapatalk
Old 05-24-2017, 04:30 PM
This is pick-up or impulse coil ,check the gap between it and rotor's marker should be under 1 mm .And check the resistance i think should be around 100 Ohms .
Old 05-24-2017, 06:47 PM
pigpen966 pigpen966 is offline
check the wire going from the coil to the spark plug. It screws into the plug cap and the coil. cut a half of an inch off and screw it back in.
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 05-25-2017, 12:25 AM
Thanks for all the suggestions, going to check it today.
Is it possible to meassure the voltage between the ground and the wire going to the ignitioncoil?
If i could get like 10-12v there, then i should be able to pinpoint the problem to the ignitioncoil, right? Or am i thinking wrong?
Old 05-25-2017, 03:03 AM
Time for an update, i got 102ohm and 14,5ohm on the coils so that is with in the range of the test values. I messured all the wires on the statorplate to see if they were any broken wires But they all were in good condition.
I tried to put a drilling machine on so i could messure the voltage output to the ignition coil But there were zero reaction. The killswitch was put out at the connectors.
Whats my next step?
Old 05-25-2017, 02:58 AM
Don't know how easy it would be to measure the signal to the coil. Most likely it is just a short pulse.
Old 05-25-2017, 03:04 AM
Shouldnt it be like on a i car, that you have about 12v to the coil?
Spark Plug 2011 EC300 iamovru Enduro Engine - 2 stroke 9 04-12-2014 09:26 AM
01 EC300 Spark Arrestor carlg Enduro Engine - 2 stroke 6 12-14-2009 07:59 PM
01 ec300 spark plug.... jhendr3702 Enduro Electrical & Wiring 1 07-02-2008 07:53 PM
