Old 06-20-2011, 06:39 AM
motogroove's Avatar
Originally Posted by stainlesscycle View Post
to the best of my knowledge, rear sprocket is not the same as drz400..
it is the same sprocket as husqvarna but a different axle size i believe..
beta/sherco may have same hubs.... i believe they are ajp..
I guess the notion here is that if the sprocket fits, maybe the hub can work?
A Suzuki sprocket that does fit is from a DR 250 or DR350 from 1990-1995.
I know it fits because I have two for my 2001 xc300
I am not sure if GG hubs have changed since 2001.
I'm looking forward to seeing how you work this out. <<<<<edit> oops, didn't notice how old this thread was
HTH
Dean
Thanks to FLY Racing.
Old 06-20-2011, 02:22 PM
gasser's Avatar
gasser gasser is offline
HTH
Dean
Suzuki made two different DR models in two different sizes during those years: the regular DR and the "S" model. Only the rear sprocket from the "S" model will fit gassers. The sprockets you have must be for a DR250S or a DR350S.
Old 06-20-2011, 02:56 PM
coopernicus's Avatar
coopernicus coopernicus is offline
Motogroove,
Look back at my posting from October and it shows what Kawasaki wheels fit for sure and what I speculate will work from some quick research. I forgot to make the update from my test on the later Kawasaki rear wheels as I picked up a 2003 KX 250. That wheel will not fit without some major thought. The 2003 (and I expect newer) KX rear axle was a larger diameter than the one from my 1999 KX 250. While you may be able to find a bearing that will fit the hub and match the GG axle I was not able to verify sprocket and disc spacing. Good luck finding something else that fits and please post if you do find something!
Eric
2018 GG 300 GP
2014 GG 300 Racing E
2002 ATK 605 Dual Sport
2003 KX/KDX 220 hybrid
2021 Kawasaki KRX 1000 Trail Edition
1974-86 Vintage Can Ams, SWMs, Puchs, etc.
Old 06-20-2011, 03:10 PM
motogroove's Avatar
Could be. I'm just going by the old label I stuck in the back of my manual (attached). I wish I could remember the name of the company... out of the former Soviet Union or something. Nice sprockets and no name.
Thanks to Coopernicus for the KX update.
I posted that other thing before reading all the pages.
dirtstars on ebay seems to be the best idea.
An extra set of wheels would be nice for many reasons.
Old 06-20-2011, 07:11 PM
gasser's Avatar
This is from JT Sprockets catalog:
DR250 L/M/N/P 90-93
DR250 L,M,N,P Off Road 90-93
DR250 S-L/M/N 90-92
DR250 SE-P,R Off Road 93-94
DR250 SE-P,R,S Off Road 93-95
DR250 SE-P/R/S 93-95
The DR250 models without the "S" use the JTR808 sprockets while the "S" models all use the JTR822 sprockets same as GasGas and late model Huskys.
http://www.jtsprockets.com/52.0.html...el_uid=6851&p=
Old 08-20-2011, 10:25 PM
lonetree lonetree is offline
so the coclusion is?
kx250 pre2003? will fit, with no mods other than spacers?
pre90 model cr250 rear?
is this correct?
not worried about sproket or rotor crossover, just hub/wheel...
cheers
Old 08-25-2011, 04:50 PM
southbound southbound is offline
I went to the RAD website, and called them for some clarification.
Eco hub $280 ("Our strongest hub. It does not have the fancy drill outs and it weighs more, but it is probably our strongest hub.)
Heavy duty spokes $70
DID wheel 18x2.15 $164
For a total (sans bearings and other stuff.) of $514.
Old 05-22-2018, 07:34 AM
Middithegasgas Middithegasgas is offline
Did the ktm fit on the gasgas
Old 05-22-2018, 07:54 AM
Anders Anders is offline
No, KTM wheels do not fit Gasgas.
plastic fitment randy General Discussions & Announcements 11 02-03-2010 03:03 PM
air filter fitment wence Enduro Engine - 2 stroke 6 12-23-2008 09:49 PM
Gaerne SG 10 Fitment Question Boomhauer Enduro Product Reviews 5 12-16-2008 07:04 PM
Aftermarket wheels. Ud_luz Enduro Chassis & Body 3 12-08-2008 05:59 PM
Gear box mess (circlip fitment) craigyboy Enduro Engine - 2 stroke 2 10-28-2008 10:11 AM
