Old 08-30-2010, 09:18 AM
PEB PEB is offline
Default 50mm zoke rebuild
I have the 50mm forks on my 07. In the last 6 monthes some of the black coating had started to wear off. The seals have been weeping a little as well. I am going to order new wipers and seals will I likely need bushings as well? Anyone used any of the snergy products and if so do you like them? Who besides Gofasters stocks zoke parts and sells them retail?
Thanks,
Paul
Old 08-30-2010, 04:01 PM
ScottyR ScottyR is offline
Junior Member
If you have a Husky dealer nearby, you might have some luck getting the parts from them as a lot of Huskys use the same forks.
Old 08-30-2010, 04:42 PM
webmaster's Avatar
Administrator
Or another option is kelly at motosportz who specializes in husky stuff...
www.motosportz.com
Or just send/take them to Les for a service - his prices are very reasonable.
www.lt-racing.com
p.s. It's normal for the nitride coating to wear off after some use - it's a very thin coating on the lower fork leg. Nothing to worry about.
Old 08-30-2010, 06:44 PM
PEB PEB is offline
Silly me, Tasky is just down the street. Jeff thanks for the insight on the coating. I think I will get the seals and wipers and then tear them down. I have never had aset of twin chambers apart, I am kinda of excited.
Old 08-30-2010, 07:24 PM
Junior Member
If you have Zoke TC forks, they are tricky to bleed. Dirt Bike Mag had a good tutorial on how to bleed them properly.
50mm shivers? eddy field1 Enduro Suspension 2 07-31-2010 06:12 PM
odd ktm/gg 43/48/zoke suspension quandry Cruiser Enduro Suspension 2 11-15-2009 11:43 AM
45mm zoke shim id Ed Ventura Enduro Suspension 1 09-22-2008 05:34 AM
Recommendations on a zoke tuner? stvbird Enduro Suspension 2 02-13-2008 06:40 AM
