Old 07-05-2013, 03:15 PM
hannesd hannesd is offline
Originally Posted by n_green View Post
This thread is a database for others to view people's jetting setups so discussion doesn't really take place here. There are plenty of threads re spooge and what it means but essentially it just indicates your oil of choice isn't reaching its flash point and burning off prior to escaping via the exhaust port. Could be due to running rich could just be that you're a lugger using less then half throttle all the time could be you're using a race type 2 stroke oil with a high flash point which you'll never reach trail riding.
For more discussion start a new thread or search for precious ones there are heaps.
ok thanks
Old 07-14-2013, 06:34 PM
Gibby Gibby is offline
Default 2013 xc300r south alabama
2nd jetting post, 1rst post feb,2013
Bike= 2013 xc300r 38mm as2,
elevation= 0 sea level - 500ft gulf of mexico.
main jet = 178
pilot jet = 42
needle = n3cj 3rd middle clip.
airscrew = 1 3/4 out
slide = #7
float height = 2mm above stock
premix 93 octane 44:1 amsoil dominator.
I have tried n1ef and n3ch, n3ch was better than stock but lacked bottom end grunt. After reading Simmo737 jetting post and Jacobi post, I
tried the n3cj and 178 main
man did this thing come Alive with low end power and keeps on kicking through top end and I have noticed fuel mileage has increased.
Thanks for the post guys I would not got here with out them !
Good Riding to all!!
Old 07-14-2013, 07:22 PM
Simmo737's Avatar
Simmo737 Simmo737 is offline
It's all jakes work, I just report the results.
Oz
Current. 2015 ec300r estart, 98 RM 125
2013 Ec300r 2011 Ec300e 2009 Husky TE310
1982 XR500 Honda 1981 KE100 Kawasaki
1978 GT80 Yamaha
Old 07-14-2013, 07:57 PM
Oz,
I see where you changed to the:
main = 175
pilot = 40
needle = nedw 2nd from top
slide = #7
from the 178 main, n3cj needle 3rd, 42 pilot.
I have not done any head mod but I have purchased the nedw needle.
I like the the power delivery with the n3cj and 178 main, 42 pilot, it does spooge alittle,great low end, seems to lack aliitle in the middle with hard hit on top. Way better than stock though. I ride tight single track. do you think I should try the nedw, 175 main, 40 pilot? What changes did you notice?
Thanks,
Old 07-28-2013, 04:55 AM
n_green n_green is offline
Bike year & model = 2011 EC300E fitted with 38mm PWK ASII carb and reed block spacer and fitted with modified head
(squish - 1.45mm, compression ratio - 12.7:1)
Temperature (degC) = 14 - 18 degC,
65% - 80% humidity
Elevation (feet) = 1000f, or 300-500m.
Main jet = 175
Pilot jet = 42
Needle & notch = NEDJ #2
Air screw setting = 7/8's turn out
Throttle valve/slide = 7 non notched
Results:
Good torquey power lugs down quite well, once on the needle it felt good, had good strong power throughout the rev range, though felt rich from 3/4 throttle onwards and fell slightly flat. A user friendly and forgiving needle for tight single track, oodles of torque down low that builds into a nice smooth strong mid and top end. Not as explosive as the N3 series needles, which in my case is a good thing as I enjoy riding the more technical terrain where the N3 series needles wears you out..
The fuel economy is great for once
10l used for 110k's on day 1 (50k's flowing single/twin trail with hills, 50k's fire trail)
6l used for 90k's on day 2 (90% fire trail).
Old 09-26-2013, 05:26 AM
Bike year & model = 2011 EC300E fitted with oval bored 36mm x 39mm PWK ASII carb and reed block spacer and fitted with modified head
Temperature (degC) = 22 - 28 degC,
40% - 60% humidity
Elevation (feet) = 3000f, or 900-1100m.
Main jet = 170
Pilot jet = 40
Needle & notch = NECJ #2
Air screw setting = 1.25 turns out
Throttle valve/slide = 6.5 notched
Results:
Good torquey power lugs down quite well, once on the needle it felt good, had good strong power throughout the rev range, though felt rich from about 1/2 throttle onwards and fell slightly flat. A user friendly and forgiving needle for tight single track, oodles of torque down low that builds into a nice smooth strong mid and top end.
11.2l used for 118k's (the last 20 k's were done on reserve and on fire trails at a conservative pace
[/QUOTE]
Old 09-29-2013, 03:15 AM
Temperature (degC) = 25 - 30 degC,
40% - 60% humidity
Main jet = 168
Pilot jet = 40
Results:
Good torquey power lugs down quite well, once on the needle it felt good, had good strong power throughout the rev range. A user friendly and forgiving needle for tight single track, oodles of torque down low that builds into a nice smooth strong mid and top end. Could have gone one step leaner on the main as it was still a bit rich, but it made good power and had good over rev so I'd prefer to leave it safe.
7.2l for 76k's. Nearly all of it single track at a decent 2nd/3rd gear pace.
Old 10-25-2013, 12:15 PM
mjtursky mjtursky is offline
Default One more for the database
Bike year & model = 2002 EC250
Temperature (degF) = 40~75F
Elevation (feet) = 1100 ft
Main jet = 178
Pilot jet = 42
Needle & notch = CEL 3rd clip
Air screw setting = 1-1/4 to 1-3/4
Throttle valve/slide = 6.0 w/ notch
Results:
Good steady idle with good mid range hit. No loading up at low speed and clean transition.
Old 11-03-2013, 03:09 PM
KTMAndy's Avatar
KTMAndy KTMAndy is offline
What is the difference between all the needles? Mine says n1ef the book lists an n1ec? I keep reading people using JDKH01 blue? CCK etc.
Has anyone got a link that cross references the different needle types and where to buy them from?
I am progressing with playing with the jets and theoretically I understand the amount of fuel/ air the jet would deliver if I move it up the clip. But what is the difference in the actual needles?
GasGas Not Ass Gas.... No more KTM EXC'uses...
www.scunnybikers.com
@Ktmandy
Old 11-03-2013, 07:04 PM
Have a search or start a new thread Andy. Simply put, needles can have various straight sections, diameters, and any number of tapers to their profile to supply varying amounts of fuel across the throttle range. The jets (pilot and main) only really impact on either end of the needles action.
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
