Old 06-03-2008, 11:16 AM
nsgasser nsgasser is offline
Default Rear Brake Problem
Hi Guys, this is my first post but I've been lurking around for a while. Great forum with lots of info!
I have an 06 EC300. I noticed that my rear brake took a couple of pumps to get any pressure and upon further inspection, my rear wheel bearings needed replacement. This fixed the problem however after about 160 km I noticed the same thing. Not nearly as bad but still needed a pump before I got any brake feel. There is no play in the bearings anymore and the disk is not warped. When I run the bike on the stand it doesn not happen. I read all the posts I could find here about bearings and brakes and saw a pic of someones spacer (goes in between the two bearings on the sprocket side) and mine is much thinner. I did not replace it when I did the bearings and am wondering if this could be the problem. I really don't want to pound out the new bearings if I don't have to and since there is no play I'm not sure if this is the prob or not. I just find it coincidental that the bearings fixed the problem completely for two rides and then it started again. If anyone has any thoughts they would be much appreciated!
ohlins rear shock problem reeve Enduro Suspension 14 06-01-2014 11:03 PM
Rear brake adjustment Silver Enduro Chassis & Body 5 06-03-2009 07:50 AM
Rear Brake Caliper blitz11 Enduro Chassis & Body 11 10-28-2008 03:38 PM
Rear brake pedal HydroDog Enduro Chassis & Body 0 03-09-2008 10:48 PM
