Old 03-03-2013, 11:12 AM
rgranger's Avatar
rgranger rgranger is offline
Default engine rebuild aftermath - i dont think this ia a good sound?
runn on pwre is good, stron and smooth at idle this rather loud clack?
Well i cant upload an mp3... Will try a google docs link after i post this
https://docs.google.com/file/d/0B25s...FfXzB5THc/edit
See if you can hear it here? I know the builder cleaned it, but i font know if it would be this loud?
Any thoughts.
Thanks rob
Rob Granger / Katy, TX EC300
Breaking more things by 8:00AM than most people break all day.
Old 03-03-2013, 07:15 PM
Zman's Avatar
Zman Zman is offline
That sounds really odd. Does it get better or worse as it warms up?
Old 03-03-2013, 09:24 PM
pscook's Avatar
pscook pscook is offline
Is the power-valve loose and rattling? It almost sounds overly-rich, like it's four-stroking. I would check the PV linkage under the right cover and see how that looks first, then work down. Maybe pull the pipe and check the PV flapper, see if it's rattling on the actuator.
Phil
(New bike pending...)
Old 03-03-2013, 09:33 PM
rgranger's Avatar
thanks for the ideas. I had planned on pulling the pipe. I made pretty sure that the nut was on the lever and red-loctited it. but my first little triangle thing busted after about 1 month. so I will pull the pipe and look under the PV cover and see if there is anything to see looking up the exhaust port. I do run it a little rich, always figured better that than lean, plus I like the smaller hit.
Looks like I will be making the 8 hour loop up to Austin to have someone look at it, I am tired of dealing with it. What sucks is when I did ride it, the suspension was awesome! added 7.5 wt to the front and it mellowed it way out, took the big hits but didn't chatter.
Rob
Engine noise after top end rebuild skraMnoR Enduro Engine - 2 stroke 10 02-26-2013 08:42 PM
needs a engine rebuild gassergrant United Kingdom 1 03-31-2012 03:28 AM
sound of the engine 300ec Enduro Engine - 2 stroke 10 02-15-2012 02:14 PM
Engine sound decel Jakobi Enduro Engine - 2 stroke 48 07-06-2011 11:44 PM
300 Hp Wild Engine Rebuild!?!? GASGAS300HP Enduro Engine - 2 stroke 2 03-16-2009 12:08 PM
