Old 06-16-2019, 10:59 PM
dzhitshard dzhitshard is offline
Default 2018 XC300 horrible sound?
https://youtu.be/YYyDUmWL-2M
What on earth is this sound coming from?
I have not been able to get the flywheel off because of lack of acceptable tool.
I have good compression, measured by stroke resistance on the kickstarter.
The FW bolt is torqued to 40Nm but I can't check crank play or not torque until I can cobble a tool to get the FW off.
The noise is barely a flutter until the bike reaches operating temp and then it becomes horrible.
It "feels" like there is more violent vibration once the noise reaches the levels in the video.
Thank you
Old 06-17-2019, 02:43 AM
Davehuge's Avatar
Davehuge Davehuge is offline
I'm guessing it's power valve or power valve linkage.
I've heard of the power valve actuating arm vibrating on the crank case.
Could also be something is loose on the power valve mechanism and the power valve is just flapping around.
First thing I would do is remove the right side power valve cover and run the engine, see what you can see.
Could also be a snapped piston ring but I doubt it as you say you have good compression. How many hours do you have on your piston kit?
It would be worth removing the exhaust and looking up the exhaust port with a torch, look at the piston/rings and also see if the power valve looks OK.
Fingers crossed it won't be anything too serious or expensive.
Best of luck and keep us updated. Dave.
Old 06-17-2019, 05:45 AM
60-80 hours on the piston.
I had a stick pull the wire out of the hour meter at some point and I'm not sure how long it took me to notice.
Old 06-17-2019, 09:15 AM
Wimpy525 Wimpy525 is offline
Go to the power valve, the linkage is suspect I had some similar issues and it was the power valve sticking closed. Just out of curiosity how many turns is your power valve at?
Old 06-17-2019, 09:48 AM
Power delivery seems consistent through the throttle range when the noise is present. Bike also has good power delivery before the noise appears. Noise doesn't seem to appear until the bike is ridden under load for a few minutes.
IIRC the PV screw is set at 1 3/4ish as it sits.
Old 06-17-2019, 12:49 PM
Davehuge's Avatar
Yes, the more I think about it, it sounds like something power valve related.
If it was a snapped ring you'd hear a rattle at idle.
Good luck, Dave.
Old 06-17-2019, 03:46 PM
Can't help, but love the expression on your son's face at the end!! such a typical "... why are you bothering with this, it still runs, we could be riding...??" look
2003 txt250 Pro
2013 Ossa 280i
Old 06-17-2019, 03:52 PM
Davehuge's Avatar
True...
Old 06-17-2019, 04:03 PM
LOL,
The video is doing the WHOOMP WHOOMP cyclic sound and vibration little justice. Especially when I was so frustrated I laid on the pipe for a solid 100yds just trying to see if I could make it let go.
That's my riding buddy's kid. He actually said something like "Holy crap, I thought that thing was going to explode coming down the logging road. What's wrong with it." My kid was gone by then but he was definitely the whatever, lets just ride guy.
Old 06-17-2019, 04:07 PM
Davehuge's Avatar
Hopefully it's not too serious, won't cost too much time or money to fix and you'll be back on the trails again soon!
Keep us updated, all the best, Dave.
Wanted 2018 xc300 gaser "Wanted to Buy" & "Want To Trade" 0 12-02-2018 12:56 PM
Need help deciding... 2018 XC300? Wypipo Enduro Product Reviews 17 09-16-2018 10:44 PM
2018 XC300 For Sale Low Hours! chunkysoup Used Bikes 2 09-03-2018 01:26 AM
Stock Jetting in 2018 XC300 AZRickD Enduro Intake/Carburetion - 2 stroke 0 09-02-2018 05:48 PM
Picked up a 2018 XC300! Adrian200xc General Discussions & Announcements 8 11-06-2017 09:09 PM
