Old 04-27-2020, 02:04 PM
Nicktamps Nicktamps is offline
Default Coolant leaking from where gasket goes on bottom of barrel
Hi all. Replaced my piston today. Put everything back together and it looks like there is a small leak from the gasket where the barrel fits onto the bottom end. Right next to the exhaust manifold. anyone had this issue before? Will I have to take it all apart again? Bikes starting up lovely and that so I don't really want to take it all apart again
Thanks for the help
Nick
Old 04-27-2020, 04:34 PM
hannesd hannesd is offline
i guess you tore up the base gasket, take it apart again...sorry mate ;-)
Old 04-27-2020, 06:38 PM
Zman's Avatar
Zman Zman is offline
I had this happen a month ago on my goddaughters ec144. It appears that the previous owner over-tightened the cylinder to case bolts and slightly warped the cylinder corners. I was able to check it with a straightedge and feeler gauge. I was able to fix it with a fine flat file and I also used some Hondabond when I put it back together.
Old 04-28-2020, 03:50 AM
So how would the coolant be getting down the cylinder that far? I thought it went into the head and acted as a water jacket. Where does it go down to the join at the bottom of the cylinder?
Old 04-28-2020, 07:33 AM
Zman's Avatar
The coolant comes from the pump through the lower case into the bottom of the cylinder up to the head and out the hose to the radiators and back to the pump.
Old 04-28-2020, 10:01 AM
So I noticed yesterday that my radiator had bent quite badly and I noticed a leak from the top of that. Took it off and straightened it up and now there are no leaks anywhere. It must have been coming down the rad onto the front of the engine somewhere. I will keep an eye on it. Going to go out and bed the new piston in tomoro. Will post an update
Old 04-28-2020, 12:46 PM
Zman's Avatar
Congrats! Have fun breaking it in :-)
barrel ec 300 Olliesherman Enduro Engine - 2 stroke 9 06-20-2016 01:36 PM
Coolant leaking through cylinder head socket-head bolts. GGRider01 Enduro Engine - 2 stroke 5 10-17-2015 07:38 PM
barrel ec 250 hippygary Enduro Engine - 2 stroke 1 07-01-2014 03:46 PM
barrel replating gassergrant United Kingdom 5 12-02-2013 06:08 AM
Cylinder gasket leaking. GavGav Enduro Engine 4 stroke (including EFI & Exhaust) 2 05-18-2009 01:25 PM
