Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > Other GasGas Bikes/Quads
Other GasGas Bikes/Quads Trials, Pampera, Wild HP, etc.
Old 04-26-2011, 08:19 AM
skoolball23 skoolball23 is offline
Default GG WIld 300 how to hotwire fan to stay on?
I have a Gas Gas Wild 300 and my fan module sensor went out. I want to know how to hotwire fan to stay on. I want to add a switch to to turn it on and off.
Old 04-26-2011, 01:29 PM
GasGasDreamer's Avatar
GasGasDreamer GasGasDreamer is offline
i'm not sure about a wild300, but on a txt280 there are two units. a fan module and a temp sensor. i believe the sensor can be bypassed by simply joining the sensor input and output wires, or adding a switch that opens and closes the circuit. but the module cannot simply be bypassed.
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
2014 Beta Evo Factory 300
Old 04-26-2011, 07:13 PM
I ran a hotwire straight from the brake line and the fan stays on all the time. It has worked so far.
Old 04-26-2011, 10:35 PM
Dude Dude is offline
One your gonna cook the fan. Two it only needs to be on at stops or really slow like 15mph cruise.
Your having issues with your coolant system for sure man. DO the leak down on the coolant system.
Old 04-27-2011, 07:00 AM
Do you think I would be okay if I mounted up a fuse and added a switch?
Old 04-27-2011, 02:40 PM
again, i dont know about your specific machine, but the fan module on a gasgas trials bike is required and cant be bypassed. i believe it converts the ac to dc for the fan. in addition to the prior posts and their warnings, i think you should look into this. hopefully i'm wrong and its all okay.
2002 Husberg FE650e
2006 GasGas EC300
2014 Sherco SER300
Old 04-27-2011, 10:27 PM
I ran a wire from the headlight and added a fuse and an on/off switch. This way I can cut the fan on when I want to. This will help keep it cooler. And for loosing the antifreeze, I think it was my head gaskets. I put new ones in and didn't lose any antifreeze so far. I will see.
Wild HP 240 Dude Other GasGas Bikes/Quads 22 03-22-2011 01:46 PM
Choke will not stay pulled up forgiven General Discussions & Announcements 10 09-05-2009 12:58 PM
wild 300 and other 300's WILDGASGAS300 Enduro Engine - 2 stroke 1 10-26-2007 11:58 AM
Kick-starter won’t stay engaged sanderjavant Enduro Engine 4 stroke (including EFI & Exhaust) 1 10-09-2007 11:17 PM
Wild 300 Hp PA300HPWILD Enduro Electrical & Wiring 0 10-09-2006 06:59 AM
