Old 12-30-2015, 11:16 AM
shang shang is offline
Default Battery Wiring
Maybe I remove my seat too much... I don't know, I clean my airfilter pretty much every ride so I don't think I really have much of a choice. Anyway... I'm sure I'm not the only one to have to re-wire their battery because of broken cables and terminals??
Soo... I finally just ordered some 10awg RC car silicone wire and EC5 RC car battery plugs. I'm downsizing wire size and I'm a little skeptical on the small plug not melting, but, it is rated to 120 amps. In theory it should be fine. The silicone wire is extremely flexible. I'll report back when I get the stuff and let everyone know how it worked out.
In the meantime, anyone else have to deal with this? What did you do?
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1983 Yami Tri-Zinger
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 12-30-2015, 02:22 PM
Rod Overstreet Rod Overstreet is offline
I'm a little puzzled at this. On your bike...Isn't there a cable attached to the battery box that goes to the sub frame cross member, that stabilizes the seat and keeps the battery terminals from being stressed?
Old 12-30-2015, 03:02 PM
There used to be. It frayed and broke and I never replaced it. I actually had a cable break at the terminal before that though from repeated flexing. It's not a big deal. I was just curious if anyone else has had a problem and curious about the solutions people came up with. I'm sure the flexy cables will work great.
It's dusty here in Utah so it seams like I'm constantly in the air box.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
Old 12-30-2015, 06:38 PM
pigpen966 pigpen966 is online now
This is what I used, works like a champ. Got it from Napa
Dick Carnes
"If ya run, you'll only die tired"
2019 EC 300
2018 GP 300
2013 XC 300 (sold)
2006 DE 300 (buddy has it)
Old 12-30-2015, 06:42 PM
hamilton's Avatar
hamilton hamilton is offline
This is on my to do list. I would like to add a quick disconnect for cables and secure the cables to battery box to prevent flexing at the terminals.
Something along this line. Need to find a quality quick connect plug.
http://www.ebay.com/itm/6-GAUGE-24-F...-/201428197889
15 GASGAS EC 250
19 Sherco SE 125R
Old 12-30-2015, 08:31 PM
scratch250's Avatar
scratch250 scratch250 is offline
Stay out of the dust, ride in front. Also maybe post an electrical topic in electrical.
Old 12-30-2015, 08:51 PM
CombatYoga's Avatar
CombatYoga CombatYoga is offline
Default Roll your own
I can tell my wires/terminal are getting a bit ragged as well Shang.
My seat wire also broke - I made a new one with some wire and some clamps from home depot (was using a couple of zip ties for a while which worked fine).
The quick disconnect cable idea is solid.
One of the most infuriating things to do on this bike is disconnect/reconnect the battery cables to the battery itself - it is a nightmare.
Slade
'14 GG XC300R - County Cycle Woods Weapon #63
Old 12-30-2015, 08:59 PM
scratch250's Avatar
Whaaat, really? Oh I get it, sarcasm....
Old 12-31-2015, 10:23 AM
I am using this connector as well right now. It works well, but it a bit of a pull to disconnect so it winds up yanking on the cables inside the box. Also the connector is big and with the stiff cables it is hard to tuck it in the airbox without letting it rub on the airfilter.
2013 GasGas XC300E
2005 YZ290
1973 Honda CB175
1997 KX60
1984 Suzuki Alt 50
1969 Trail 90
1971 Trail 90
1972 Trail 90
can i add a battery gassergrant Enduro Electrical & Wiring 1 08-13-2014 10:13 AM
2002 ec300 light wiring and speedo wiring help needed. andy176 Enduro Electrical & Wiring 0 02-04-2014 07:38 AM
Fan - no battery eliasn101 Enduro Electrical & Wiring 0 02-26-2012 04:53 PM
Battery for a 07 450? fastisbetter Enduro Electrical & Wiring 2 03-29-2011 08:06 PM
