Updated: 2013 XC300, Help Turning The Lights Back On
Help!
I started undoing electrical tape on my XC to fix a broken wire on my e-start, and have opened Pandora?s Box! FYI, E-start is all good... now to fix the lights! What voltage should be coming into the light switch on the yellow wire? Is it DC or AC? I see one leg of the yellow comes from inside the stator / gen cover. The other yellow conductor that feeds the yellow leg of the light switch (3-way splice) comes from the regulator. I?m reading .1VDC or 1VAC while checking the yellow with the bike running and revving. I get 12VDC at the brake light. The starter relay seems good, the two fuses are good and the bike will kick start without a battery (key on tho). It also sends charge voltage to the battery leads too (no batt connected for that test). Help! What voltage should I see on yellow, and where to look next?!? Thanks! Last edited by BLD; 07-20-2018 at 12:59 PM. Reason: More details, less words! |
I gave my 2013 XC300 A Mud Bath! | BLD | Ride Reports | 1 | 01-30-2018 03:03 AM |
2013 or 2014 xc300? | earlystock | General Discussions & Announcements | 21 | 04-19-2014 02:36 AM |
dual sport kit on 2013 xc300 | mikeg | Enduro Electrical & Wiring | 6 | 06-12-2013 02:51 PM |
2013 gas gas xc300 E UPGRADES | lordofhurley | General Discussions & Announcements | 2 | 06-08-2013 07:33 AM |
2013 xc300 E | lordofhurley | General Discussions & Announcements | 1 | 05-06-2013 07:18 PM |
