#11
Make sure you do a voltage drop test as well. Very common for dirt bike harnesses to have shitty crimp joins internally and it drops voltage by the time it goes back to the battery. If you check the charge rate straight out of the regulator and it is significantly higher than at the battery you have an issue.
2018 EC300 Speedo Battery Code | malin | Enduro Electrical & Wiring | 1 | 07-31-2018 03:31 PM |
Lithium Ion battery and E-start for 2013 ec300 | stockacr125 | Enduro Electrical & Wiring | 0 | 01-28-2018 01:21 PM |
not charging battery | OLD.IT | Enduro Electrical & Wiring | 2 | 06-21-2015 03:01 AM |
Charging phone on 2011 EC300 | Quigs | Enduro Electrical & Wiring | 9 | 03-07-2015 12:55 AM |
Battery Not Charging | GLantern | Enduro Electrical & Wiring | 6 | 08-25-2013 03:45 PM |
