Old 11-01-2010, 01:46 PM
kendunn kendunn is offline
Originally Posted by stainlesscycle View Post
that washer 09180-22045 is 22.1x45x? 45mm o.d. is probably fine, but i can't find the thickness. if someone has a local friendly suzuki shop, you could probably stop by and measure it....
can't remember how i looked up that thrust washer...
can you direct me to the old thread (can't seem to find it...) maybe it will refresh my memory.
Have a look at this thread....
http://www.gasgasrider.org/forum/sho...1-22423&page=2
I tried to look up the size with no luck, something I love about GG (measurements on parts). Called my local dealer and no luck
2006 EC300, 2000 XR650R, 2003 EC250, 2001 EC200 (OK, the last two are really my sons).
Old 11-01-2010, 02:04 PM
stainlesscycle's Avatar
as long as it's between 1.5 and 2 it will work. at 2mm my clutch dragged a bit, i re-milled the thrust down to 1.5 (i think) and it stopped dragging....i have not had to mess with my clutch since. i was into it after every race until i did this mod....
07 ec300
www.stainlesscycle.com
Old 11-01-2010, 02:35 PM
dank's Avatar
dank dank is offline
alright so let me summarize and see if i got this right. the plates from a late 90's honda cr250 will fit, but the frictions are the wrong thickness. and to remedy this, you get a thrust washer that is 1.5ish mm thick. is this correct? also does anybody know if a different manufacturers basket will work? i cannot find an aftermarket for mine, and i bought a used one, but its only a matter of time before that one gets grooved too.
03 ec250
hyde skidplate, cycra handguads, protaper contours
"what? it seemed like a good idea at the time!"
Old 11-01-2010, 03:09 PM
correct. you replace the 2.7mm thick one with one that is 1.5mm thick.
you can rejuvenate the basket by filing the fingers. but that adds play to the frictions, which causes the basket to wear faster (and possibly break frictions...)... anyways, you can go quite a long time on a basket until it's too abused to run...
i'm assuming i can do 50+ races before my basket is worn out, and i abuse the clutch, if that's what it takes...... i'm guessing that's probably equivalent to 1000 hours trail riding...
07 ec300
Old 11-01-2010, 05:01 PM
I ordered a kit for a 90-97 CR250R (Tusk brand, $45 from Rocky Mtn) because anything after that had two different metal plates, 5 were steel and 2 aluminum. I don't know how this would work in a GG, but I thought it better to stick with all steel. Also it has springs which will also (fingers crossed) work. I have heard the CR clutch baskets may work, but not sure. Seems like a long shot with the gear teeth, but who knows. Also I think you run into clearance issues and have to stack gaskets.
I am hoping to find a thrust washer (may even try a plain ol' washer, I guess its just softer??? could use it to test anyways) that will work because I hate to do something irreversible to my stock parts. Stupid washer from Gofasters would be around $40 with shipping, that is robbery, especially considering the Jap crossover is $3.
My kit should be here before the weekend and will post what I find. I hate it when people start these threads and then leave you hanging when they figure it out but don't post.
Old 11-01-2010, 05:34 PM
plain old washer and thrust washer are significantly different. most thrust washers are porous and impregnated with lubricating substance... also a thrust washer is load/velocity rated, and machined to a higher tolerance. plain old washers are just stamped....
the only critical measurement is 22.1mm i.d. - o.d. can be 42-45, and thickness can be 1.5 to 2mm..
if you convert all this to inches, you will find a .75"x1.75"x.0625" thrust washer will work almost perfect - you would just need to bore the i.d from .75 to 22.1mm
this thrust washer is probably $1 at mcmaster.com
any machinist could bore a 22.1mm hole for a few dollars..
it's harder to machine the original thrust washer down to 1.5mm - the magnetic chuck doesn't work well with this material for some reason. it wanted to keep moving, and i wasn't gonna build a fixture for that little washer...
07 ec300
Old 11-01-2010, 07:02 PM
dank's Avatar
i'm assuming i can do 50+ races before my basket is worn out, and i abuse the clutch, if that's what it takes...... i'm guessing that's probably equivalent to 1000 hours trail riding...[/QUOTE]
call me anal if you like, but i would rather not shatter a friction. i did buy a used basket that is in better condition than my own, which will suffice for now.
03 ec250
Old 11-01-2010, 07:56 PM
when the friction plate breaks, it's not a big deal (they don't shatter - they just break into 3 or 4 big pieces - usually..), they stay in the basket (the steels hold them in..)....just do a thorough engine flush and replace. you may not even know the plate has broken....clutch will usually still engage, just drag bad on disengagement.
07 ec300
Old 11-02-2010, 09:33 AM
iancp5's Avatar
iancp5 iancp5 is offline
Originally Posted by Qui-gon View Post
Are you sure they are only 50 quid? If so I will get a set while I am back here! I cant believe something is actually cheaper in the uk!
http://cgi.ebay.co.uk/CLUTCH-FRICTIO...707790ff8d8ab4
http://www.trialendurodirect.com/ind...h=15_17&page=2
But any Gas Gas dealer should be able to sort you out. Last set I bought from a dealer were about the same price. Maybe they don't get them from the factory. Either way they worked fine and didn't need any modification. If the DP ones are as good as their brake pads they should be excellent.
Old 11-02-2010, 11:18 AM
s3 makes a basket .
http://www.trialendurodirect.com/pro...odels_875.html
07 ec300
Crossover Clutch Mastercylinder leejames Enduro Engine - 2 stroke 2 07-21-2010 08:45 PM
Clutch Basket Crossover eff Enduro Engine - 2 stroke 13 03-07-2010 07:37 PM
GG 125 clutch crossover jayc Enduro Engine - 2 stroke 3 07-08-2009 11:51 AM
125xc clutch crossover? jayc Enduro Engine - 2 stroke 0 04-01-2009 12:23 PM
250/300 clutch parts crossover Skidad Enduro Engine - 2 stroke 5 01-09-2008 11:54 AM
