2002 rear brake pedal
It says in parts crossover that a kx pedal will work with mods. Has anyone out there done this? What kind of mods & what year kx pedal. Thanks
Why would you even want to do that? After years of dealing with cheesy Kawi controls that wear out rattle and shake!
Because the guy at go fasters told me a brake pedal was $165
That cant be right can it? Who did you talk to? If it is correct go ahead and use the kawi one, its not rocket science! If you can write your name in the dirt with a stick, One would think it should be very straight forward.
Brake pedals are very expensive.
HTS-2000 aluminum brazing rod, ($65/lb.) and Burnzomatic MAPP tourch from Home Depot will repair shifters and brake pedals for years, providing you have the pieces.
roller bearing rear brake pedal | mxdj2003 | Enduro Product Announcements | 25 | 12-16-2008 09:29 PM |
Rear brake pedal | HydroDog | Enduro Chassis & Body | 0 | 03-09-2008 10:48 PM |
Rear Brake Pedal | Rick | Enduro Chassis & Body | 4 | 01-28-2008 01:57 PM |
