Sachs shim 7ID & 9ID, where I can buy?
I'd like revalve my 48 sachs fork.
Can anyone tell me where I can buy 7mm & 9mm ID valving shims? (small piece(44), shipping to Europe/Hungary) SDI(suspensiondirect),Racingsuspensionproducts: only 9ID MXTech,RaceTech: I can't see Thanks |
A while back I saw you could get them from the Beta site, the alternative is to grind out a smaller size with a dremmel
Are these the 10' red Sachs Forks and are you in the U.S. ?
2015 KTM 450 XCW 2014 350 XCF Wife's 2009 200 ec. Loving it 2007 Beta Rev 3 270 2007 KTM 200 XC Wife's Public Lands belong to the Public Last edited by husley; 07-22-2016 at 03:09 PM. |
No.
It's a 2009 sachs fork (not racing version) See pictures. I'm in Europe. (Hungary) https://goo.gl/photos/97AFLkumSXBd1ywr6 |
Dremmel is not a good idea. See this post: http://www.gasgasrider.org/forum/sho...hlight=dremmel |
The Sachs forks on the Betas continue to use 7mm ID shims.
Beta does not stock the 7mm shims, but we have built some for our own use. The plan had been to have them for large term sale but the process is such that it hasn't made sense to do so.
You could also contact Michigan Engineering as they offer 7mm id shims on their website. I have just googled it, I have never been in contact with them. http://www.mei-inc.com/machine/shim/id_7_mm.htm Sent fra min GT-I9295 via Tapatalk
Thank you Guys!
Marzocchi 48 shim stack profile. | Barbs | Enduro Suspension | 17 | 02-29-2016 07:12 AM |
Marzocchi 45 shim advice? | motopsycho87 | Enduro Suspension | 17 | 10-20-2014 12:47 PM |
Countershaft sprocket shim | 3hunerd | Enduro Engine - 2 stroke | 5 | 03-24-2012 09:29 AM |
45mm zoke shim id | Ed Ventura | Enduro Suspension | 1 | 09-22-2008 05:34 AM |
Rebound shim recommendations (stiffer) | stay_upright | Enduro Suspension | 4 | 09-20-2008 02:20 PM |
