Old 05-13-2009, 03:02 PM
lukemillar's Avatar
lukemillar lukemillar is offline
Default EC-400 FSE - Identifying Fuses
Hi,
Been looking through the manuals and can't find any reference to the fuse box. I have taken some pics and was wondering if someone could tell me what each fuse relates to(Numbered 1-8 in the pic. Also, I have this odd fuse in the box (number 7) which has no continuity across it however I have no idea what it relates to. Any help would be much appreciated:
Fuse Box lid is scored, so I can't read what was on it!:
Fuses 1-8
Mystery Fuse Number 7 - no continuity:
Lastly - anyone know what the hell the fuses are supposed to bolt to? Looks like something should attached to the battery, but there is nothing there!?:
Thanks
Luke
2006 Triumph Daytona 675
2004 Gas Gas 400 FSE
Old 05-13-2009, 06:08 PM
lukemillar's Avatar
Ok, I think I have figured out the diode and it's purpose from the 2005 FSE 450 wiring diagram.
Old 05-14-2009, 03:16 AM
iancp5's Avatar
iancp5 iancp5 is offline
Well...? What?
Old 05-14-2009, 05:15 PM
lukemillar's Avatar
Originally Posted by iancp5 View Post
Well...? What?
Diode sits between the ECU and the solenoid and I think it is to prevent spikes. Continuity wasn't reading because voltage threshold was too low for diodes, though it has a diode setting which reads ok.
As for the rest of the fuses, I could go over all of them and figure out their purposes, but I was kind of hoping for a quick answer on here.
Old 07-08-2013, 03:17 PM
doddi1 doddi1 is offline
please be a dear and post your findings after you figure out the answer to your problem
the internet is a karma bank.
you give and thou shall receive
the internets will thank you
