#11
Seven point five.
#12
...But oils aint oils!
#13
#14
What I mean is that even comparing one brand of 5wt to another brands 5wt doesn't mean they are the same viscosity.
#15
It's supposed to have 7.5wt oil. I put valvoline maxlife atf in mine as it works out around 7.5, dexron 2 and 3 are closer to a 10w but if I were you i'd aim for about 12.5 at the very least.
http://mahonkin.com/~milktree/motorcycles/fork-oil.html Bare in mind you won't find a 12.5w fork oil so select a thinner 15w from the list. Also, while your low speed (round edged bumps) damping may improve, your high speed damping will get harsher (sharp edged bumps).
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
#16
Phil (New bike pending...) |
#17
The labelled weights don't mean much. The viscosity is what matters.
I believe the Marzocchi 7.5wt is around 26.40@40cSt and 9.90@100cSt In comparison Silkolene RSF 5wt is 26.70@40cSt and 9.46@100cSt Thats just one comparison. Also, regardless of what the manufacturer recommends, its also just another tuning variable and more importantly is selecting a particular oil and working with it to achieve the desired goals. A lighter oil will pass through the valves quicker. Lighter compression damping, and a faster rebound. In my closed chamber I've been using Amsoil 5wt hich is only 15.9@40cSt and 4.4@100cSt. |
#18
Well Ive been playing around with these 45's and think Ive got it dialled now.
Ive made from delrin 20mm spring spacers to give the fork a bit of help as I felt it had a lot of sag and soft feel in the first part of the stroke, as well as going from my 5wt oil up to 10wt. Oil level was good as it resisted bottoming by around 10mm landing on flat ground from a 6ft drop. The fork now feels a lot more progressive in its travel, and does not dive through the first half as quickly. Ive a day woods riding planned this weekend so time will tell, just hope it don't start pushing the front in corners or over roots |
Marzocchi 48 advice | Diggs345 | Enduro Suspension | 41 | 04-10-2014 09:54 AM |
Countershaft sprocket shim | 3hunerd | Enduro Engine - 2 stroke | 5 | 03-24-2012 09:29 AM |
45mm zoke shim id | Ed Ventura | Enduro Suspension | 1 | 09-22-2008 05:34 AM |
Rebound shim recommendations (stiffer) | stay_upright | Enduro Suspension | 4 | 09-20-2008 02:20 PM |
05 EC250 Marzocchi stock shim arrangement ? | ferguscawley | Enduro Suspension | 10 | 01-10-2008 07:49 AM |
