Time for Front end change .. Questions to those in the Know ..
OK ,
So I have read the Fork Conversion threads in this forum like 3 or 4 times each.. I am ditching the 45 Marzocchi front end on the `11 -300 Possibly on the `11-200 as well .. and I have a couple of questions. 1) On the `11, does anyone know the offset for sure ? is it 21 or 22 degrees? 2)I seem to recall a thread by elvis74 in Germany (Maybe) about a kit with a front wheel spacer and a front caliper adapter bracket with scar triple trees. any one know if that or a similar kit is US available ? 3) there seems to be a small divide in the I like this brand topic: who will give their opinion about Showa or Kayaba .. I am going to get some front forks bought this weekend and Start this process next week ... Please help by giving me some confidence about my conversion decision .
]| 2011 Gas Gas EC 300 Six Days ]| 2011 Gas Gas EC 200 Six Days ]| Team Chesapeake RV Solutions Gas Gas Racing ]| DUAL SPORT ARMORY Suspension ]| Hampton Roads HVAC.com Contracting "You mean I have to put oil on the gas too?" " Where is Kutcher ?" |
Hey JD, I've herd a coupla fella's have used the forks off a newer yz. Girard aka
gasgasman has done this mod. Best of luck. Last edited by john r b; 03-08-2014 at 08:02 AM. Reason: spellin |
Yeah John , I have located a pair SSS forks from a YZ .. I think im gonna get them
Sent from my SCH-I545 using Tapatalk
Buy now, figure out the details later!
http://www.gasgasrider.org/forum/showthread.php?t=15863
2011 GasGas ec300R 2011 GasGas ec200 Six Days |
I did a fair amount of research into this and you need to get 2006+ yz forks and triples and then you need to get a brake caliper adaptor for an oversized rotor (also yz)
I am not sure what my final answer on the front axel but I think the final option was a yz axel and spacers and different bearings. There is a lot of info on it here on the forum
Fork upgrade
Hey J.D,
Best improvement you can do to the GG. Not all that difficult. I used 09 yz forks Revalved by LTR. Used my GG front wheel with different bearings and the yz axel. Had to machine the spacers a tiny bit in order to centre the wheel. No big deal. Used the yz triple clamps and changed one bearing. As for the brakes I used the GG calliper and just welded up one hole and redrilled and tapped it to fit. Wasn't that difficult just required a bit of patience to get it lined up. I'm super happy with my old 06-300 now. Dave |
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
what about the CC WP? this is the way I went and I am very happy. I just bored out the lower clamp a little so there was no pressure on my forks. and picked up a ktm wheel everything bolts up same brakes and everything lines up. really easy upgrade.
Rebuild time questions | swazi_matt | Enduro Chassis & Body | 5 | 02-10-2014 03:12 AM |
Time to change out sprockets and chains | AZRickD | Enduro Engine - 2 stroke | 23 | 12-12-2008 10:37 PM |
Front brake is on all the time | Larsa | Enduro Chassis & Body | 7 | 11-11-2008 03:13 PM |
Oil change time-which viscosity=fork/shock | motorhead | Enduro Suspension | 5 | 10-04-2007 06:56 AM |
