#31
This would be good to have. Can you provide some instructions on how to adjust the belcrank (when you post pics)?
Matt Current: 2009 Yamaha FZ1 Previous: 2001 GasGas TXT280, 2001 GasGas XC250, 2004 KTM 200EXC, 2007 GasGas EC250, 2007 Husqvarna SM610, 2008 Husqvarna WB165 |
#32
I get what you're saying about the preload on the actuator rod Glen. On mine the actuator plate rests against the stop with engine off, but I would characterize the "preload" as very very slight. I could envision it rattling with that slight pressure against the stop. I just fired her up for a heat cycle after a new top end. I will pull the right cover and see what's going on in there when running. Is it just a "feel" thing when setting that preload or is there some "scientific" method?
Ross '05 MC 250 '91 Husky 610wxe '04 Duc M800 R.I.P '06 Duc S2r 1000 R.I.P '07 Duc S2r 1000 still rubber side down... ---------------------------------------------------------- May be so... May be not so... My Website |
#33
Yes, just a slight preload by feel. The force is the governer spring acting on the rest of the system. This is not a documented procedure, just something I thought was a logical way to fix my '03 that did not appear correct.
Sorry guys, too much kids sports stuff to mess with photos tonight. I will try to do it this weekend though. |
#34
Power valve setting
Reassembled cylinder and PV assembly and noted that with the engine off the exhaust valve bracket (part#35) was not resting against stopper bolt (part #33). The gap between both is about 5 mm, then in lifting the stick lever rod (part #1) it is evident that no preload is on the stick lever, thus allowing the stick and the bracket plate to move freely back and forth and hit the stopper bolt Part #33- Is this my dreaded rattle I hope so. So, how do I adjust the PV assembly to put some preloaded on the stick / valve bracket to reduce the possibility of the bracket moving back & forth hitting the stopper bolt. This rattle is doing my head, not to mention my wife is frustrated with me obsessing with my bike- again. Refer photo: ttp://picasaweb.google.com/hoff49/MyPictures?feat=directlink
Noel 07 Gas Gas 250ec Newcastle, Australia |
#36
Noel,
You have one of two problems, both require removal of the side cover. After the oil, coolant is drained and the cover is removed, you need to verify that the PV governer balls are not displaced and jammed, as this will prevent the PV from closing. This is usually caused by pulling on the actuator rod with the engine off, manually moving the governer and allowing the ball(s) to fall out of position. If this is the case you can manipulate the governer to reseat the balls. If the governer is OK, then the position of lever #6 on lever axel #4 must be adjusted. Loosen setscrew #5, fix or hold the actuator plate to the stop bolt, and while pushing the governer assy straight into the case with a grip that will put just a slight preload on the governer spring, tighten setscrew #5. Its eaiser to jam the actuator plate against the stop with something unless you have a helper to hold it there. Its obvious when you have the side cover off. The idea is to provide just a slight preload (closed) to the mecanism by the governer spring. You may have to do it a couple times to get it right. I'm sorry about no photos, but this PC has some USB system issues and my thumbdrive with the photos takes a very long time to be seen by the system. |
#37
O.K. for future reference here's a report on my "rattle."
I rode the bike for about three hours yesterday and did not produce the rattle. Previous to the top end job it occurred regularly when pulling hard at low rpm. Must have been piston slap like someone else reported a while back. Cyl. replated, new top end = no more rattle in those "lugging" situations. I did not put the "missing washer" in. (#39) I still have a lot of end play in the PV assembly. I wanted to think it was the PV because that would have been easier and cheaper, but it obviously was not. I couldn't quite envision how too much end play could cause a rattle like I was hearing, but that optimism... I can definitely see that a misadjusted actuator rod like Noel has could do it.
#38
So how much rattle is too much?
This is my first modern 2 stroke - at low to mid revs mine sounds like a chain slipping over a cog (not loud though) Is this the norm please? |
#39
Hi Guy's
Pulled off side cover to review the balls in the PV governor, I can see the balls only at the lower part of the governor, does this mean they have fallen out of position, if they have does this mean I have to disassemble the governor to reposition them or can I reposition them by laying the bike on it's side then pushing the governor inward then manipulating the balls into the correct position. Need to get this sorted, didn't ride on the weekend, we had plenty of rain this week in the land of OZ - perfect for the Gaser
#40
In my case the rattle was more consistent when pulling down low than the rattles others described as more intermittent or occasional and attributed to chain slap, PV etc. Sorry haven't delved into the PV govenor.
FSR 450 valve check and timing chain | ggg | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 04-22-2010 01:40 AM |
Cam chain Slap - FSE 400 | lukemillar | Enduro Engine 4 stroke (including EFI & Exhaust) | 11 | 08-25-2009 10:57 PM |
Power valve | bens25au | Enduro Engine - 2 stroke | 2 | 02-09-2008 11:02 PM |
Chain Slap | Malcolm | Enduro Chassis & Body | 4 | 12-04-2007 05:05 AM |
