Go Back   Rieju & GasGas Legacy Riders Club Forum > Other Bikes... > All Other Bikes...
All Other Bikes... KTM, Husky, VOR, Husaberg & Hondayamazuki...
Old 06-20-2017, 09:17 AM
Moto7man Moto7man is offline
Default Wide Ratio Transmission Ready for Installation
A few more pictures. Engine build to start ASAP.
―Comedian Lewis Black
-Unknown Sardaukar
Old 06-25-2017, 08:05 PM
Default Engine Build Started
New shift case.
New brake side case.
-Unknown Sardaukar
Old 06-25-2017, 08:18 PM
The cases fit together really well, no machining needed.
New Honda Oem crank,straight from the box.
Wide Ratio IMS transmission
-Unknown Sardaukar
Old 06-25-2017, 08:34 PM
Parts stacked next to workbench waiting for install. Dan,the penguin isn't for sale.
I used a puller tool to move the crank into the case half. I used two tire irons wrapped in cardboard to rest the tool against the case half. It worked really well. The IMS Wide transmission dropped right in without a problem. Note:The stock transmission has two 23 tooth gears, one on the the countershaft and one on the main shaft, the gear on the mainshaft is a little wider, if you reverse them, the transmission will bind when you install the other case half, this was per Dogger 315 on another site. I measured my two gears, which are IMS gears which are a different size than oem and I made sure that the wider gear was on the mainshaft.
The cases came with all the bearings installed except one of the transmission shift drum bearing. I don't want to use the old one so I have to order one tomorrow.
-Unknown Sardaukar
Old 06-25-2017, 09:28 PM
The last 96 CR NOS Cylinder in North America.
New head still in the Honda bag.
This is a "B" cylinder so I bought a Wossner "B" piston.
New piston in the barrel.
Misc power valve parts. I replaced the round cover and o ring along with the lever mechanism and head bolt. I ordered a new circlip.
I used this moly for the PV assembly.
-Unknown Sardaukar
Old 06-25-2017, 09:39 PM
Barrel assembled just waiting on a circlip and new cylinder studs.
-Unknown Sardaukar
Old 06-26-2017, 08:04 AM
Zrt1200 Zrt1200 is offline
Glad to see you are making some headway. Keep the pics coming. I was looking at the pic with the piston in the cylinder and noticed the bottom of the exhaust port looks like it does not have a chamfer on the port edge??? Are the ports chamfered??
Old 06-26-2017, 11:25 AM
Thanks! I ordered some more parts today. I'll look at the cylinder when I get home. I want to complete the build in two weeks then it is time to ride!
-Unknown Sardaukar
Old 06-26-2017, 03:11 PM
2 weeks sound like a good time frame to break in a new bike. Check all the ports top & bottom for a chamfer as you dont want to be scuffing up a new piston or catching a ring in that bad boy.
Old 07-06-2017, 10:09 AM
gasgasxc gasgasxc is offline
I told you!!!!!
DC conversion - not floating ground johnm Enduro Electrical & Wiring 39 03-04-2020 11:11 AM
Gas Gas Contact Jt 25 95 Restoration And Help Eyetech General Discussions & Announcements 1 03-18-2016 03:33 PM
2001 XC200 Restoration Project Lincolnlock Enduro Engine - 2 stroke 19 04-22-2014 03:42 PM
Hanging Idle after wide open GasGas Enduro Intake/Carburetion - 2 stroke 10 09-06-2013 04:13 PM
My Stomping ground swazi_matt Ride Reports 10 03-02-2011 09:35 AM
