#11
Early bikes had the nickel frame thru about 03'. 2004+ bikes had the silver powder coat frame. Yours sure looks like a 99' with the counter balance engine, that fuel tank and nickel frame. Have fun with it!
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
#12
Just pulled the master cylinder apart, I can't seem to figure out what is suppose to push the plunger in to activate the brakes. Is it mounted on the lever it's self? or is it an other piece. The brake lever has a screw with a nut on it inline with the plunger. Hi Ho Hi Ho Learn as I go......haha |
#13
All frames were nickle up to 05
02 EC 200 03 MC 250 88 VT 800 01 TXT 280 |
#14
pretty sure all 200s use the 250/300 frame of their era which would explain the 250 frame no.
Most brake levers have an adjustable screw which the head activates the plunger,the screw adjusts the lever freeplay.based on your picture im guessing the thread in your lever is stuffed and someone has drilled it out and put a bolt right through. You can either rebuild master cyl and install a new lever or fit a new m/c which will prob come with new lever
2013 ec200r |
#15
That would explain that.....lol
#16
My buddies show room condition 2004 with the trials style gas cap has a powder coated frame from the factory.
