#31
I have used both and they will work just fine for the riding you will be doing. The Kenda is probably a little better tire. The washugal works well here in Indiana
Sent from my iPhone using Tapatalk |
#32
I'm really interested in Endurocross stuff, looks fun and challenging, yet not crazy fast with huge jumps and stuff. |
#33
Haven't tried it yet though. Depending on the terrain which varies wildly here in Idaho...everything from hard pack desert, shale bolder fields, super slick mud to slime covered rocks and roots (all in one ride ) I run Michelins. M12's, S12's...and AC10's. I am going to give that Kenda a try next. It comes in a 19 too... http://powersports.kendatire.com/en-...d/equilibrium/
2017 Beta 300RR |
#34
if you want to get some extra life out of a tyre,buy an$80 knobby knife.this lets you recut the rounded knobby edges back to square.typically i cut mine 3 or 4x then its new tire time.also saves the tire being removed/fitted a bunch of times or rotated.usually on the 2nd cut i also cut the lateral edges to get a bit of edge grip back.worthwhile on rears,not on fronts which usually last 2or3x longer than rear.takes about 20min each time,with no need to remove wheel
2013 ec200r |
#35
If you are just learning and basicly play riding around the house, throw a trials tire on it.
Cheap guys run trials tires. |
#37
#38
I only notice how well a tyre hooks up when its new as its replacing one that's well done. Tyre pressure and clutch control takes care of things generally. When riding I find that a bald tyre in motion still does quite well. If conditions are poor and you're stopped it can highlight its short comings. Just makes you work a bit harder.
I've use Dunlop MX51 rears pretty much exclusively on the last couple bikes. I can get them at decent prices. I can get decent range out of them (700-1000kms generally), and they work predictably through their lifespan over a wide range of terrain. Seem to offer a nice balance between all the compromises. Personally I'd be more inclined to pull the tyre and flip it than spend time with a knobby knife.. but that's just me! And I don't often bother flipping a tyre without reason. Racing is a different animal. I'd take performance and terrain into account and use the best match you can - and start with a freshy. I also found when I was slower I used to used to wear the rears much quicker than the fronts. These days I find the front gets worked over equally as hard. Not a lot of flex in the forward direction, but working the side lugs in the corners and the forces it experiences under brakes definitely take their toll on fronts. Likely also spend less time unintentionally spinning the back tyre, and more time finding traction with it. |
#39
