Old 02-25-2008, 07:05 AM
Patswild300's Avatar
Patswild300 Patswild300 is offline
Originally Posted by iancp5 View Post
I'm at sea-level with an EC300 bike but found the CCK needle really helped. I tried all sorts before including LTR and couldn't get a smooth power delivery. I ended up jetting very lean (35P, N1EF on #2, 178M, #7 slide) as it "appears" to run better that way in the woods but you get that hit and it's dangerously lean when you come to a fast section. It seems better because it gets rid of most of the 4 stroking at small throttle openings. I now have 42P, CCK on #3, 180M, #7 slide and it's much better. Could probably go to 45P.
Make sure float height is correct before experimenting. It was the needle that made the difference for me, until I had that right no pilot or main change could sort it. Thanks to Pobit for suggesting CCK needle.
Great info.....The float was the first thing I set.. Where can I get the CCK needle? Do you think I should go to a #7 slider?
2004 Gas Gas
Wild 300
ITP beads all
around
Old 02-25-2008, 09:24 AM
iancp5's Avatar
iancp5 iancp5 is offline
Any Keihin agent should stock them. It's a standard Keihin needle. I believe Sudco are one of the main agents in the US?
Old 02-25-2008, 10:06 AM
Loosenut's Avatar
Loosenut Loosenut is offline
I would try a 40 pilot, needle clip in the #3 position based on you brief description of the midrange bog. With the larger load from the quad, I would keep going up on my main jet until the performance dropped off. You might be able to pull a up to a 175 at the higher elevations and it's important if you plan on spending alot of your time on the pipe/MJ.
Mike
Old 02-25-2008, 10:29 PM
Mike
Thanks Mike
It had a #40 pilot and it was worse I think, Thats why I went with the #35 and went another half a turn out. I was going to up the main another size up and see..I also tried the needle in the middle and it had the hesitation so I went to the 2nd fron the top and it cleaned it up alot..
2004 Gas Gas
Wild 300
ITP beads all
around
Old 02-26-2008, 09:21 AM
barkeater's Avatar
barkeater barkeater is offline
The LTR powervalve cover helps with bottom end. We put one on a Wild HP 240 and it made a difference on the bottom end. I also have one on my EC200 and noticed a difference as soon as I put it on.
Todd A
2003 EC/O 200
Old 02-27-2008, 07:00 AM
Thanks Barkeater
2004 Gas Gas
Wild 300
ITP beads all
around
Chain slider question. Please help joey11 Enduro Chassis & Body 3 12-05-2008 06:43 AM
chain slider / chain guide crossover? bondo General Discussions & Announcements 1 09-01-2008 09:13 PM
