#11
In a full wave rectifier circuit, you can do one of two things: Float the AC side or float the DC side. They CAN NOT share a common ground. If I remember there was a detailed procedure on modifying the stator to float the AC common. It does not require rewinding, just a simple mod with a soldering iron. The AC side is then isolated from engine/chassis gouund, and the +12V DC ground may now be connected there.
#12
Thank you, This is the kind of concise answer I was looking for.
Not what I wanted to hear, but, a positive answer one way or another. I have reviewed and copied the instructions for floating the ground from several web sites. So I have accurate documention on "How to do it". Most of the articals show how to re-wind the stator's poles as well as which wires to disconnect. Im sure I can figure out how to de-solder and splice a new wire into the system. Time to break out the tools and get to work. Thank you for your help. Jeff Wallace |
help and advice please 400 output shaft | Paul Somerville | Enduro Engine 4 stroke (including EFI & Exhaust) | 0 | 11-01-2009 03:14 AM |
stator crossover | bronco-hunter | Enduro Electrical & Wiring | 2 | 12-14-2008 09:21 AM |
EC300 Stator Output | Magellan | Enduro Electrical & Wiring | 10 | 07-21-2006 12:12 PM |
