#11
The GG water pump uses a high speed graphite/ceramic industrial pump seal. The shaft is not a wear surface. You have to be sure that it is pressed in square and flat when replaced, along with correct orientation of the parts, and that the surfaces are smooth. If its an ongoing problem check the bearing.
97 blew the head gasket? | Cruiser | General Discussions & Announcements | 11 | 08-08-2011 09:40 PM |
Clutch cover gasket ? | cbutler | Enduro Engine - 2 stroke | 3 | 06-20-2010 11:29 PM |
Gas Gas success | roostafish | General Discussions & Announcements | 6 | 01-22-2010 06:15 AM |
Base gasket | Ud_luz | Enduro Engine - 2 stroke | 21 | 05-09-2008 07:38 AM |
Base Gasket | gtsnowcrack | Enduro Engine - 2 stroke | 6 | 09-09-2006 05:43 AM |
