Old 02-15-2007, 08:11 PM
gasIdaho gasIdaho is offline
Default Front Axle/Wheel Removal
OK...I'm embarassed to even ask this but here it goes. How do I remove my front axle so I can pull my wheel off? This is the first time I've attempted to pull the wheel off my GG. The axle is different than other motobikes I've had in the past that simply took a wrench or socket to loosen. Looks like I need a big hex to put in the non-disk side. Any idea what size?
Old 02-15-2007, 08:31 PM
Brian VT Brian VT is offline
Remove the bolt from the disk end of the axle. Loosen the 4 bolts on the ends of the forks that pinch the axle. Slide the axle out.
Front Axle noobi Enduro Chassis & Body 10 09-21-2009 09:51 PM
Front Wheel Bearing Removal coolum74 General Discussions & Announcements 13 02-24-2009 03:29 PM
