Bike is too tall! Any suggestions
I'm picking up a used 2018 300 gasser which I am told is about 1.5 inches taller than my 2011 bike so my plan is to lower it 1-1.5 inches on both ends. Please give me info on where to have this done. Thanks
How tall are you brother?
bought them myself but still do not know if I should use them or not. Maybe on the first fork oil change cause I m still low on hours
EC250 2019 |
Seat concepts has a low seat option that works well.
If you do the lowering links option you need to drop the front end a corresponding amount or the front end will push badly in corners. You can do this by raising the forks in the triple clamps or by using internal travel limiting spacers. Your handle bar height will limit how far you can raise the fork tubes in the triple clamps.
I am not sure what size tire is on your bike now, but you may be able to lower the bike with shorter tires. If you can lower it enough with a seat mod and tire change you can keep the suspension at full length. |
I don't race and I don't ride on mx tracks so losing an inch of travel at each end is no big deal - it would still have twice as much travel as dirtbikes had 50 years ago when I started riding. I will add thicker seat foam since I ride sitting most of the time. I will get the front fork lowered internally. I'm thinking the same for the rear since I've never liked my results with longer linkage rods. Any suggestions on where to get the suspension work done?
I sit a lot too.
The low SeatConcepts foam is just the right density. |
Terry at Norwest suspension does suspension lowering. I did some work on my 2002 300, and he was able to provide parts for the Ohlins and WP forks on my bike. I did springs (becoming heavier), seals, bushing on both fork and shock. He was great. |
Do a online search, I'm sure his name will pop up. RB |
50/50 tire suggestions? | Why Z? | Enduro Chassis & Body | 3 | 05-22-2014 06:20 PM |
2012 Tall Seat or Tall Foam/Cover???? | rickster2 | General Discussions & Announcements | 4 | 09-21-2012 08:38 PM |
Bike won't start - suggestions please. | stay_upright | Enduro Engine - 2 stroke | 22 | 04-28-2011 01:27 PM |
Tall man trials bike | lankydoug | Other GasGas Bikes/Quads | 4 | 09-03-2010 10:07 PM |
