Old 02-20-2008, 10:48 AM
steve steve is offline
Default assembly
2 questions, 1] Do you apply assembly lube on the wrist pin rod bearing and or any other area?2] How much lube,pre-mix I assume,is the proper amount for top-end assembly? I have done this before,but for the sake of sounding stupid I've never asked.Any input would be great.Thanks in advance!!!
Old 02-20-2008, 06:55 PM
Nick's Avatar
Nick Nick is offline
There as many ways of doing this as there is oil stories. Personally i just use a very small amount of oil to make the parts slide together easier.
Old 02-20-2008, 08:08 PM
kim kim is offline
I just lube everything inside the motor with the premix oil you normally mix with your gas.
That way you know it will burn off and/or mix properly and not leave a film of something unwanted.
Worked so far for me.
K
08 TXT 300
06 Gasgas EC200
03 Gasgas EC300
05 Pampera 250
Moto tas reed assembly Knobbiethrower Enduro Engine - 2 stroke 3 09-23-2008 02:56 AM
