#11
I have fitted my new reeds, the old reeds had seen better days and 1 was split.While I had the carb off I noticed 2 of the pipes coming from the carb were clogged with mud so I cleaned them out. The problem is now cured completely, the bike now runs superb from low revs all the way to the top! and is consistant with it. As it was sugested the damaged reeds must have been overfueling it at low rpm.Thanks people for all the help.
#12
I apologize in advance for this long post...but I have spent nearly 3 solid moths trouble shooting this problem.
I have had this dilemma for awhile with my 2001 EC 250 and I think I have finally come close to figuring it out. Let me first say that I bought this bike used and did not know the maintenance history. It ran like crap and fouled plugs from the moment I bought it. It would not come on the pipe and it smoked like crazy. After I replaced reeds, checked the power valve, swapped CDIs, replaced the right side crank seal, rejetted with a LTR Kit (180 main, 42 pilot and clip in the middle position on an LTR needle), checked the float level multiple times, changed brands and heat index of plugs, repacked silencer...etc, nothing improved. I went for a test ride the other day and noticed that as the bike started to run out of gas, it perked up and ran fantastic. The moment I switched to reserve and supplied fuel to the carb, it started to bog out and smoke again at 3/4 - WOT. This means I needed to lean the bike by adjusting the main jet or reduce the fuel level somehow. I did both... Today, I replaced the needle valve assembly in the float bowl which controls fuel entry into the bowl and went from a 180 main to a 172. I am also 3.5 - 4 (way too many) turns out on the air screw. The problem is almost gone. I may try a smaller main to see if it improves. The only thing I am concerned about now is that somebody in another posts mentioned a spring that surrounds the needle jet under the float tab... I do not have one of these in my carb.
_______________________ 2001 GG EC250 2000 Ducati 996 |
#13
It is still possible that your carb is worn out. I know I have seen 2 gassers newer than yours that needed new carbs. However, you can have your carb fixed, tweaked and jetted by Ron and be done with all the BS. I plan on sending Ron a carb this summer. It should be interesting. Mike |
#14
What is Ron's address? How can a carb be worn out? I might look into him rebuilding my carb.
Disassembling Powervalve | steve | Enduro Engine - 2 stroke | 7 | 10-22-2013 03:35 PM |
ltr powervalve cover | moff747 | Enduro Engine - 2 stroke | 5 | 03-05-2008 01:24 PM |
powervalve tention | fullthrottle | Enduro Engine - 2 stroke | 0 | 12-30-2007 07:43 AM |
LTR powervalve cover | ejas | General Discussions & Announcements | 2 | 08-23-2007 08:09 AM |
