Old 05-02-2015, 12:25 PM
Hulle Hulle is offline
Smile
Hi!
Thanks for all information, I just installed the EXP to mine MC 250, 2003 and IT seams to work well, i have a small drag when i have a gear in, It's really greate to run whit the autoclutch
I put 1,8 mm washer on the outside of the lifter, took some time to get the right hight but now it works well, no slip what i can tell
Cheers 😀
Gasgas 250 MC 2003
Old 01-23-2016, 05:57 PM
rvangeel rvangeel is offline
Are the guys that are putting in the rekluse exp buying the exp for a 94-07 cr 250? I'm thinking about trying it.
Old 02-01-2016, 08:38 PM
BigAl BigAl is offline
This is the thread I was looking for will update it when my Rekluse arrives
05 GG EC 300
Rekluse
Smart Carb
SSS Front & Ohlins Rear by MPE
FMF Gnarley & Powercore 2
2013 (4t) Racing update Kit
Old 03-05-2016, 01:18 AM
So simple, CR250 Rekluse Core, then just used 2 extra GG washers on top of the normal 1 and all is sweet, will be giving it a good try out tomorrow
05 GG EC 300
Rekluse
Smart Carb
Old 03-05-2016, 07:02 AM
I can't wait to hear. Thanks again. What year cr250 clutch did you buy? (I assume you mean 2 stroke right?)
Old 03-05-2016, 01:45 PM
Rekluse RMS-6013, Cr250R (92-07), Crf450R (02-08) (14-15). CRF450X (05-09) (14-15)
05 GG EC 300
Rekluse
Smart Carb
Old 05-20-2016, 07:16 PM
How is your rekluse working? My friend just installed one in his bike and now he is faster than me in the woods!
Old 05-20-2016, 09:54 PM
Going Great, Love it more each time I Ride it
Every 1 that has ridden it since it went in loves it as well
05 GG EC 300
Rekluse
Smart Carb
Old 05-30-2016, 04:54 PM
Lian Lian is offline
Does put a Suzuki thrust washer 2.0mm instead of stock 2.8 mm under clutch hub make sence (clutch hub to basket spacer) when converting to a CR250R cluth plates?
We have hydraulic clutch that push long clutch rod (which push pressure plate), so if overall plates pack size is bigger than standard (34.5mm CR250 vs 33.3mm GG300), then after additional 2-3 pushing clutch lever that long rod will be pushed forward that extra 1mm and stay there forever.
So i don't understand how changing thrust washer are changing something?
Besides that - basket, plates and pressure plate is one whole assembly, which moving inside (in engine) when changing that washer to thinner one - so really nothing happens to compensate new pack height of CR250 plates. Only 6 springs are more preloaded (~1mm), but i see you never feel that after conversion.
Does the way of my thoughts right?
Old 07-13-2016, 10:23 AM
shawbagga's Avatar
shawbagga shawbagga is offline
Don't spose someone could point me in the direction of the thread that talked about clutch burnishing(to eliminate drag apparently) could they please? Searched but can't find. Cheers
TXT 200 pro clutch.. jhendr3702 Other GasGas Bikes/Quads 1 01-28-2011 10:10 AM
Clutch problems gaser Enduro Engine - 2 stroke 5 11-15-2010 07:51 AM
Clutch going out? Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 5 07-30-2010 01:00 PM
450 clutch, same as DRZ? Devondan Enduro Engine 4 stroke (including EFI & Exhaust) 2 10-01-2009 07:58 PM
What clutch oil is best? wence Enduro Engine - 2 stroke 5 08-20-2009 03:57 AM
