Came home and as i pulled onto the drive my rear brake caliper was loose and locked the back wheel up/ lucky i got home and wasent riding still. the fixing (not sure what its called) inbetween the swingarm and wheel what the top caliper bolt screws into must of been cracked and has broken off and nowhere to be seen. where can i get one from or would one of a 250 like this fit?
http://www.ebay.co.uk/itm/Gas-Gas-EC...item2ecefec51c Bike is a 2002 ec 300 |
200/250/300 are the same chassis from what I have read, so any frame/chassis/brake bits should swap right over.
Phil (New bike pending...) |
Hi mate thanks for that. D u know what the part I'm talking about is called so I can give seller details easily ??
A pic would be helpful
My guess from your description is that it's the caliper bracket. It has a slot in it to hang on the swingarm tab as well as a hole for the rear axle. It acts as the wheel spacer as well as caliper bracket.
If it looks like this, then you have a part number as well. http://www.gasgasrider.org/forum/sho...26&postcount=7 Entire thread here: http://www.gasgasrider.org/forum/sho...racket+caliper
Thanks thats what im after dont know why it snapped it seemed fine before had alot of stones hitting the bike from being pebble dashed tho.
Thread Tools | |
Display Modes | |
Brake caliper help! | yourmatedave | Enduro Chassis & Body | 5 | 05-18-2013 05:40 AM |
Brake caliper kits | cladoo | Enduro Other... | 2 | 04-19-2012 07:47 AM |
Rear Brake Caliper | blitz11 | Enduro Chassis & Body | 11 | 10-28-2008 04:38 PM |
TrailTech speedo -- brake caliper whole outside the arc | AZRickD | Enduro Electrical & Wiring | 17 | 07-30-2008 01:13 AM |
