Old 06-24-2020, 02:26 PM
Jackeett Jackeett is offline
Default Power valve governor help
Hello complete novice here needing help. EC 250 2008. Is the governor (part with the ball bearings) unsure its even that. Should you be able to move it side to side and up and down. Generally feels loose. I'm trying to locate a rattle thank you in advance. Jack
Old 07-22-2020, 08:19 AM
Down2fix Down2fix is offline
Does it rattle when you lug it under a load?
2011 ec250 all the scorpion racing goodies, fmf gnarly, lector carb, fully setup for hare scrambles.
Old 07-22-2020, 08:26 AM
http://www.gasgasrider.org/forum/showthread.php?t=9517
Check out this thread
Power valve governor assembly help! Tman Enduro Engine - 2 stroke 5 05-13-2020 10:59 PM
ec 250 power valve governor what year gg did change from 4 ball to 6 ball rvktm Enduro Engine - 2 stroke 3 04-16-2020 05:49 PM
Exhaust Valve Governor Assembly mcnut Parts 3 11-13-2015 10:36 AM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
