Old 10-12-2012, 02:14 PM
ryangroch ryangroch is offline
Default Fork oil level in 45 zokes 2011 300 ?
whats the oil level suppose to be at in each fork ? changing my seal and dont know the correct oil level. thanks alot
Ryan
Old 10-12-2012, 03:30 PM
bchatt's Avatar
bchatt bchatt is offline
Bronze Level Site Supporter
I run mine at 105mm, spring out. This equates to 540ml in each leg. If you do a search you should be able to find quite a few posts on this. From memory, my level is a little higher than most. It works fine for me - I am 75kg, stock springs. The oil height affects "bottoming out" characteristics.
Barry
07 EC250
Old 10-12-2012, 09:32 PM
twowheels's Avatar
When the bike is properly sprung (and revalved, especially in the case of the 45mm Zokes) a better number might be 130mm, with 7.5wt oil filling the legs.
Steven Beane #275
afterhourscycle.com
Old 10-12-2012, 09:47 PM
ScottyR ScottyR is offline
Junior Member
That is what I run. The 7.5W oil is critical in those forks IMO.
Old 10-13-2012, 12:39 AM
thanks alot scott!
see how she turned out for the last ride on er tommorow!
Ryan
Old 10-13-2012, 12:42 AM
rgranger's Avatar
rgranger rgranger is offline
Really, i have been running 5, maybe i will try some 7.5 and see how it works. have to find some, local shops only carry 5.
Rob Granger / Katy, TX EC300
Old 10-13-2012, 06:00 AM
twowheels's Avatar
You may have to blend some of your own ... almost every shelf brand is offered in 5 and 10 wt.
Steven Beane #275
afterhourscycle.com
Zokes oil level? jostby Enduro Suspension 2 06-20-2009 11:29 AM
Fork oil level ? Brian VT Enduro Suspension 4 03-10-2009 08:57 PM
Changing fork oil in Zokes? ktmguy23 Enduro Suspension 2 03-21-2007 11:53 PM
WP Fork Oil Level MattR Enduro Suspension 11 08-02-2006 10:40 AM
