Old 12-01-2020, 08:09 AM
J.B J.B is offline
Default ec125 2013 melted piston
Hi I have a 2013 ec125 that I converted to a supermoto. And it was running grate but then I geared it down so it would go faster. After that I rode it for about 500 meters and then the piston was melted. Do anyone know if the gearing could have caused the piston to melt?
Old 12-01-2020, 12:09 PM
If you were traveling west to east you would be going faster wrt to the rotating planet. Not sure if that would require any gearing change.
Old 12-01-2020, 12:50 PM
J.B J.B is offline
It ran perfectly fine before I change the gearing and after that it ran fore about 5 min and then the piston and cylinder was gone.
Old 12-01-2020, 06:30 PM
Ok we'll start again.
So you geared it, I'm going to guess Up rather than down so it could achieve a higher speed before hitting top revs in 6th?
The gearing won't affect the engine. The air mixture or fuel type vs ignition timing (usually fixed) could cause detonation that rapidly destroy pistons.
But tell us about the usage. Were you screaming its guts out full throttle, or had you just closed throttle?
Old 12-01-2020, 09:37 PM
Remember. Every time you go fast and let off the throttle, with the clutch engaged, the motor is turning with the throttle closed. This means there's little lubrication in the cylinder.
Old 12-02-2020, 01:58 AM
And the marginal pilot jet becomes the primary supply of cooling fuel.
Lubrication damage will look different to detonation. Have you taken it apart yet?
Old 12-02-2020, 05:07 AM
J.B J.B is offline
Yes I have taken it apart. and the front of the piston is melted. And yes I meant that I geared it up. But I geared it a bit too high so the engine wasn't able to rev out at 6th gear. And before the gearing change it ran fine without any problems. So I have no idea what could have caused the piston to melt.
//John
Old 12-02-2020, 12:20 PM
So that's detonation for sure. Less likely to be timing or too hot a spark plug which tend to kill the centre. I'd say too lean jetting or airleak. The longer time under full load may have exposed a long standing issue.
Old 12-02-2020, 12:33 PM
J.B J.B is offline
Okay thanks for the help.
//John
Old 12-03-2020, 06:32 PM
Gearing it up would put more load on the engine and that can cause it to detonate if you have too much ignition timing and/or not enough fuel octane.
EC125 & MC125 NOS Piston kits crazycooter Parts 2 06-02-2016 03:07 PM
Piston for gasgas ec125 2013 Fasulia Enduro Engine - 2 stroke 1 12-17-2013 06:53 PM
EC125 - Asso Werke Piston Ring???? kevells United Kingdom 0 10-09-2011 01:10 PM
EC125 Piston Identification? kevells Enduro Engine - 2 stroke 1 08-23-2011 04:59 PM
second melted piston in one month proelton Enduro Engine - 2 stroke 4 04-22-2010 12:03 AM
