#11
You could tack weld a button head machine screw to the back of the mount. This would provide a stud for mounting the pipe.
#12
I used a 3/4"x2 1/2" strip of sheet metal with a bolt hole in one end. Place the end with the hole between the bracket and the "nut" and then run the bolt in. Then fold the sheet metal down over the back of the "nut". It provides a smooth surface for the tank to rub against. I did also file down the back of the "nut" a bit too. |
#13
Brand new 2001 EC 300, I had to cut off the FMF pipe mount and re-position and reweld it to line up with the tank dent. P.-I.-T.-A$$
I replaced the hanger with a Kaw part made of steel and rubber as the stock alum. part broke after a fall. I guess I really didn't need it from what some have said above. |
REAR CALIPER SUPPORT clearance | Klausen | Enduro Chassis & Body | 1 | 10-22-2010 02:10 PM |
ec 250 broke off pipe to exhaust silencer | freshplaster | Enduro Engine - 2 stroke | 3 | 06-15-2009 10:17 AM |
Rear linkage brackets lower mount | 3hunerd | Enduro Suspension | 2 | 10-16-2008 09:42 AM |
