Old 04-02-2018, 03:36 PM
Could you post a pic of what you have added?
2018 XC300
Old 04-02-2018, 07:41 PM
I just happen to have the seat and tank off mine. This is what my dealer added and then I added a Shorai battery and haven’t had an issue one.
The first photo shows the new ground cable attached to the stator housing.
The second shows the other end of the cable connected up by the coil.
The 3rd is the “new” battery.
Old 04-02-2018, 08:28 PM
Thanks for the pics! Going to have to do that to mine next.
2018 XC300
Old 04-03-2018, 04:18 PM
Gibnut Gibnut is offline
Mine was having a little trouble starting in gear on hills after stalling - spinning but not starting - so last night I put in a Skyrich/SSB 220cca battery & ran a dedicated earth from the starter mount to the battery -ive terminal.
Old 04-07-2018, 11:27 PM
Starter worked super-strong in gear on hills today - appears to be fixed.
How good is the suspension on these bikes? Superb.
Old 04-15-2018, 07:53 PM
400exc 400exc is offline
So it is seeming that the starter cable upgrade, battery 220 cca upgrade and possibly the CDI re-map is fixing the problem. Is the e-start button now starting the bikes when cold or are you using the kick starter for the initial start and the e-start button for subsequent starts?
Old 04-15-2018, 11:19 PM
arminhammer arminhammer is offline
-5c bike was not started for a week. This is after the upgrades. https://www.youtube.com/watch?v=Gwu4ZiTYpf4
Old 04-16-2018, 08:52 PM
Thanks for the video. My 2018 spins the motor really well but it will never fire up when cold. I see you replaced the rotor too. Maybe that's the next problem to address. I will contact my dealer tomorrow.
Old 05-05-2018, 04:43 PM
Enduroger's Avatar
Enduroger Enduroger is offline
I have a 18 EC250 and my dealer sended me a Skyrich 4Ah 240cca battery and a ground cable that runs from the battery to the startmotor bracket. And also a positive (red+) cable from battery to the starter relay and now it starts both hot and cold.
Before the upgrade it only started when the engine was hot and the battery was fully charged.
Old 05-06-2018, 02:57 PM
Gottsell Gottsell is offline
Is it a ground cabel the black that come with the battery?
I thought that it was a replace for the thiner + cabel to start engine.
2018 Starter Fix Thread - Continued. webmaster Enduro Electrical & Wiring 162 04-26-2023 02:57 AM
2018 Stoby General Discussions & Announcements 23 04-18-2018 04:07 PM
2018 Batteries and Starter Doesnt work! markwoodlief Enduro Electrical & Wiring 81 11-30-2017 03:50 PM
2018 Starter Delete nhgas Enduro Electrical & Wiring 1 11-10-2017 07:58 PM
