Old 10-13-2008, 02:18 PM
sammyj18 sammyj18 is offline
Hey Guys,
Almost there but I ran into a new problem. I reinstalled the carb and was ready to try starting but.....when I turn on the gas it immediately starts flowing out the overflow tube on the carb. What did I do wrong when I put it back together?
Thanks,
Sam
Old 10-13-2008, 02:33 PM
Brian VT Brian VT is offline
Your float isn't lifting the shutoff needle high enough.
You may have installed the tab thing upside down ? It's that little piece of sheet metal that the pin slides through.
Old 10-13-2008, 03:02 PM
2 strokes 4 life's Avatar
2 strokes 4 life 2 strokes 4 life is offline
The float is stuck allowing fule to flow freely. Try and tap the carb with a hammer or mallet lightly. If that does not free it up take it apart and make sure nothing it caught up.
2002 Gasgas EC250 (gone not forgotten)
2012 Ktm 300xc
2001 Gasgas EC300
Lifes journey is not to arrive safely at the grave in a well preserved body, But rather to skid in sideways totally worn out shouting holy cow what a ride !!!!
Old 10-13-2008, 04:11 PM
WHEW ok I can't thank you guys enough! I took apart the carb again resprayed everything with carb cleaner and blew it all out with compressed air...reinstalled and it worked like it should, MAN that carb is a pain to shoehorn in and out of position. After that I confirmed the bike was getting a good spark, and it took about 5 kicks but it started! I just let it sit and idle and revved it for a while, ill put all the plastic back on and take it for a ride in the morning. Ran fine little rough im guessing from the blown reed valve. Thanks again guys you saved my bike from the scrap heap!
Sam
Old 10-13-2008, 04:16 PM
Skidad's Avatar
Skidad Skidad is offline
AWESOME
Now wasn't that fun
Old 10-13-2008, 05:20 PM
Now you just stay away from still deep water and you will never have to go through that again, but sometimes its hard not to.
2012 Ktm 300xc
2001 Gasgas EC300
Old 10-13-2008, 05:27 PM
jhendr3702's Avatar
jhendr3702 jhendr3702 is offline
glad to hear the good news....
i was absolutley sick to my stomach when my 300 went underwater and died..... first time I have ever done that. If it is a question at all now, I get off and walk the crossing first.
broken down over 60 slow rider..
Old 11-21-2008, 06:06 PM
vgstef vgstef is offline
Angry water and bearing = bad
I just did the same thing last week , I try to flush the water by remouving the spark pluk and kick kick kick. Re-start the bike and after 1 minute the engine seize. The main roller bearing seize on the crank godd the engine was only at idles. Cost me a rebuilt the engine over , Two bearing, seal and gasket. look at the bearing
Next time I will make sure that all water in out of the crankcase.
Eric
Old 11-21-2008, 07:30 PM
PEB PEB is offline
Use the case drain!
Old 11-21-2008, 08:01 PM
Default drain
Originally Posted by PEB View Post
Use the case drain!
I did not know about this drain until I rebuilt the engine
GNCC opener today Skidad Off Road Racer's Corner 3 03-03-2009 03:48 PM
yay my endurance came today mountain thumper Enduro Electrical & Wiring 1 02-15-2009 08:11 PM
Went Riding Today and..... coolum74 Enduro Engine 4 stroke (including EFI & Exhaust) 2 11-30-2008 01:12 PM
SHNF From Today Boomhauer Pictures & Videos 13 10-30-2007 04:18 PM
ISDE Starts Today! Mark Berg - CPD General Discussions & Announcements 31 11-21-2006 09:27 PM
