#1301
That is the correct cable. Maybe have a look at the throttle valve and spring connection? This cable fit like a glove on my bike. best of luck.
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
#1302
Should the cable receiver on the carb be straight, or a 45* elbow (like on the PWK)? Mine is straight...
#1303
straight on both ends . no 45's
#1304
The M-P 10-3000, is the longer +4'' cable. Many bikes have this cable and it fits/works well. Check to make sure the cable end is all the way up into the slide and routing is correct.
#1305
I was referring to the actual brass receiver fitting on the carb, not the cable...
#1306
roger that, I'm pretty sure all pwk's had straight fittings @ the carb cap.
#1307
OK, I'm convinced that I have the wrong cable (although it was labelled 10-3000). I need something longer... The slide is definitely not closing all the way. Not even close. Photos show the cable attached to the carb. Adjusters are in all the way on both ends. One of the slide with cable attached. One showing how far the slide is open with cable attached...
EDIT--- I went on the Motion Pro website. Cable housing length for the 10-3000 is 41.73 inches, which I have. Measuring exposed cable on my OEM cable (while attached to the OEM carb with slide closed) is 2.75 inches. Exposed cable on the Motion Pro (while attached to SmartCarb with slide closed) is 2.05 inches. Any thoughts or recommendations? Last edited by myrcrocks; 05-05-2014 at 11:32 AM. Reason: more info |
#1308
The nipple on the end of the cable does not look to be fitted in the slide right , to my eyes anyhow , it should sit inside the recess
#1309
No it is right, you poke it through the hole and then it sits in the slot.
#1310
2011 EC300 2013 TXT300 Factory Replica 2014 Polaris Assault 2004 Snowhawk 600H.O. |
APT SmartCarb | siaknijustin | Enduro Product Announcements | 19 | 10-02-2012 08:12 AM |
